Originally Posted by mtnmarmots
Thanks for the reply. The Radio Shack PRO is a trunking scanner. I may just have not set it up properly.
the "pro" part of the model number does not signify what band the scanner is capable of receiving. For example, my pro 106 will pick up way more than my pro 95. You may want to look at getting a pro 106 or GRE PSR500 if you like handhelds. Or a Pro 197 or PSR GRE600 for base/mobile. Other than that you are pretty much out of luck.
