epbernstein said:
There is what sounds like a major fire in/near Johnstown. MAC-6 is active, as is Weld fire. Mutual aid from Windsor, Berthoud, and others. First time I've heard MAC active since I loaded it. Sounds like a serious situation.
WELD COUNTY - Firefighters worked through the early morning hours Monday to put out a fire at the Johnstown Feed and Seed building.
The fire started around 11 p.m. inside the building. Witnesses said they heard multiple explosions before the fire started.
Officials used reverse 911 to notify 50 residences south of the building to evacuate their homes. They were allowed back to their homes about four hours later.
Firefighters have not been able to enter the building because of a collapsed grain elevator. They have been pouring water on it from above.
The fire was nearly extinguished by 9 a.m.
A special evacuation crew was called in to tear metal away, allowing firefighters to get inside.
No injuries have been reported in the fire and officials have not determined a cause of the blaze.
