Does any fire depatments in Adams and Weld Counties use VHF/UHF for dispatch? Thank you.
Not true. An example of a digital pager is the Motorola Advisor Elite which uses FLEX Synchronous protocol. That's Frequency Shift Keying generally at 1600 bps due to bandwidth limitations and simulcasting limitations. FSK is a digital mode.No pagers can receive a digital or trunked system. Only analog.
Many agencies utilize FLEX paging (thou their use is decreasing) either using the service of a public paging company or by using their own infrastructure. The latter is probably waning due in part to narrow banding.
RTL-SDR can be used to decode FLEX transmissions.
RTL-SDR Tutorial: POCSAG Pager Decoding - rtl-sdr.com
Morgan county pages their FD's county wide on the 800mhz system ... last time I ran procom it even showed the page going out
But to the OP question we are paged out on 460.400 out here on the east side of the county (Weld)
