Helo air to air freq
aprswatcher
Lewistown, Montana
If the weather gets good enough for copters to start flying I would start with
The frequency of 123.025 am it is a very common rotary wing air to air freq used throughout
front range. Also try 123.05 am.
These freqs are used by medevac and news copters to give position and intentions to each
other.
73, Rex
jimmnn
Colorado
Media choppers are up and providing some pretty impressive video from the air.
Jim<
ChrisP
Portland, OR
Don't forget 123.075 MHz as well. Also very popular with the helicopters...
- Chris
Spirit
Larimer County
I just heard them say they were working on 123.12 but when I put them in it comes out 123.116666. So are we not able to pick this freq. up?
autovon
Ø
123.12 in aviation speak is 123.125 so you will be able to pick it up
Silver506
Boulder
Air-to-Air Flood Frequencies
Helicopters are having a hard time getting into the area today due to low ceilings, rain, and clouds all the way to the ground in some areas. The ones I am monitoring are using military frequencies. The have just called to RTB. I presume they came out of Buckley.
Regarding the event frequencies, the federals teams have instituted their own radio systems using primarily VTAC channels. They.ve airlifted their own repeaters to various mountaintops. This frequency system is dynamic and changes hourly.
They have also intituted a system identical to the one they use in fighting forest fires. They have an Air Attack twin engine aircraft (Beech King Air, etc) flying the CAP at 10,000 feet. The Boulder County frequency yesterday for him was 123.125 and his counterpart over Larimer County was on 123.975.
The FM frequencies for these two locations for Air-to-Ground coordination was 166.85 for Boulder and 166.9125 for Larimer County.
I have not heard any activity yet on the event air frequenices as not aircraft have arrived yet.
Robbie04
Colorado
Have been hearing some air to air helicopter traffic (NG or regular Army) at 308.100 mhz. Obviously involved in rescues around Lyons and Estes Park.
Robbie04
Colorado
Sounds like the copters are staging out of Chrisman Airport in Ft Collins for runs up and around Big Thompson canyon. Air to ground at 169.200 and 119.650.
Robbie04
Colorado
Larimer Airtac located at 127.325 mhz. Hook (Chinook) 22,23, Hawk (Blackhawk) 98, Lakota (light helicopter) 72
Robbie04
Colorado
Christman field is a private airstrip, north of Horse Tooth reservoir. It is being controlled by Larimer airtac.
Mojaveflyer
Denver, Co
Flood Helo Freqs...
Try 119.075 MHz as well. I heard it active today while at Boulder Muni Airport. Evacuees coming off of a Blackhawk being assisted by 1st Responders at Boulder Muni...
abqscan
DataBase Administrator
Moderator
AOA
119.075 is being called rotor victor. I'm also hearing it patched to 411.5
135.65 is another air attack
Mojaveflyer
Denver, Co
Air Controller @ Colorado Floods
Anyone know who 'Mustang Mike' is, controller ID at Boulder Floods? Unknown freqs being referenced to coordinate military choppers...
tyytor
Wyoming
also got command on 168.100 buckhorn?
also still hearing 135.65,169.20, 168.650
from north of the border
abqscan
Moderator
AOA
123.125 is being used for the Fort Collins Interagency Dispatch Center if access is needed into the TFR area.
abqscan
Moderator
AOA
119.625 and 134.55 are also in use.
