Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Colorado Radio Discussion Forum
Colorado Radio Discussion Forum - Forum for discussing Radio Information in the State of Colorado.
Old 09-24-2013, 2:38 PM
Default DTRS Prospect Mountain new CC
First post!
After Prospect Mountain stopped working correctly for me I did a little investigating.
I found the control channel on a new frequency: 852.6375
I looked in the RR database, but did not find this frequency listed with Prospect Mountain.
Cheers!
Old 09-25-2013, 10:35 AM
Default 852.6375
I logged Prospect Mt on Labor Day and it was present then.
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0085","vi",851.53750,"00-0085",806.53750,0,18
"00-0125","av",851.78750,"00-0125",806.78750,0,103
"00-0171","av",852.07500,"00-0171",807.07500,0,782
"00-0261","av",852.63750,"00-0261",807.63750,0,61
"00-0451","c",853.82500,"00-0451",808.82500,0,0
Anybody log it recently when it was busy. Wonder if they had the resources to add channels for the flood recovery?
Chuck
Old 09-25-2013, 1:57 PM
jimmnn's Avatar
Originally Posted by NV9O View Post
First post!
Cheers!
Can you log it with Pro96Com if possible and post the Tower File.
Thanks Jim<
Old 09-25-2013, 6:49 PM
I have relocated to front range until roads are repaired. It will be a while before I have an opportunity to log the site. Sorry.
Old 09-26-2013, 9:51 AM
greenthumb's Avatar
Colorado DB Administrator
I added that frequency based on Chuck's post - it was on an alternate CC so I'll assume that the primary CC had an issue and it was a temporary thing unless logging shows the old primary as an alternate.
Colorado Database Administrator
Rules and guidelines for forum post content
Old 09-26-2013, 10:40 AM
Default Re: DTRS Prospect Mountain new CC
I'm in Estes. I'll see what I can grab.
Sent from my DROID RAZR HD using Tapatalk 2
Old 09-26-2013, 12:51 PM
Has indeed changed. I believe this one may have changed last Friday. There was a power outage in the valley and then the radio techs took the site offline for a while.
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : D1C
System Name : Colorado DTRS
WACN : BEE07
Tower Number (Decimal): 3-52
Tower Number (Hex) : T0334
Tower Description : Prospect
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Thu Sep 26 11:38:08 2013
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625, 1
-Frequencies
"00-0125","av",851.78750,"00-0125",806.78750,0,9
"00-0171","av",852.07500,"00-0171",807.07500,1,21
"00-0261","c",852.63750,"00-0261",807.63750,0,0
"00-0451","a",853.82500,"00-0451",808.82500,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
343,"T032B",d1c,"00-0331",853.07500,""
361,"T033D",d1c,"00-0421",853.63750,""
362,"T033E",d1c,"00-0461",853.88750,""
Old 09-26-2013, 4:52 PM
greenthumb's Avatar
Are you seeing any voice traffic on 853.825? That would be the telltale sign...
Old 09-26-2013, 7:16 PM
Not sure. Only ran that for a few minutes before work this morning. I will try again later and see what I come up with.
