Westminster P25
scanlist
Scanning since the 70's to today.
Greeley, CO
No alternate CC information or neighbor data being broadcast at this time.
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 5C8
System Name : Westminster P25
WACN : 927A7
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Tower Description :
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Sat Oct 19 07:01:41 2013
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,806.06250,0.01250,-45.00000,"Confirmed",0.00625,1
01,811.00000,0.01250,-45.00000,"Confirmed",0.00625,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-3871","c",859.38750,"01-3871",814.38750,0,0
greenthumb
Colorado DB Administrator
Cool, thanks Phil!
I don't expect to see any neighbors on that simulcast system and Tait is probably like Harris with regard to broadcasting alternate CCs. That seems to be a Motorola thing for now...
And added this system to the database:
http://www.radioreference.com/apps/db/?sid=7771
Steve2003
Colorado
Finally starting to see some activity on this system!
Grant Logs:
"Timestamp","Type","Channel","Frequency","TG ID","TalkGroup Description","Radio ID","Radio Description"
"10/22 12:33:53","Group","00-3998","856.03750"," 201","T: 101 DT: 10/22/13@12:33","1002","TG: 201 DT: 10/22/13@12:33"
"10/22 12:34:24","Group","00-3998","856.03750"," 201","T: 101 DT: 10/22/13@12:33","1002","TG: 201 DT: 10/22/13@12:33"
Affiliations:
"Timestamp","Function","TG ID","TG Description","RadioID","Radio Description"
"10/22 12:33:47","Affiliate",201,"T: 101 DT: 10/22/13@12:33",1002,"TG: 201 DT: 10/22/13@12:33"
"10/22 12:36:00","Unaffiliate",0,"",1002,"TG: 201 DT: 10/22/13@12:33"
Steve2003
Colorado
Looks like control channels switch like the Harris systems on this one. CC is now on 856.0375.
FileVersion:7
-TowerInfo
System ID : 5C8
System Name : City of Westminster
WACN : 927A7
Tower Description : Simulcast
Call Sign(s) :
Timestamp : Tue Oct 22 22:27:00 2013
-Tables
-Frequencies
"00-3998","cv",856.03750,"00-3998",811.03750,0,0
"01-3871","c",859.38750,"01-3871",859.38750,1,0
Steve2003
Colorado
So far I have logged the following talkgroups on this system. Anyone able to catch any audio?
38501
Most recent talkgroup, logged today. RadioIDs 860023, 860024. Perhaps this correlates with EDACS TGID 501?
200
201
202
203
204
Edit: Pro96Com grant log attached (Open with a text editor or save to your PC and change the file ext from .txt to .csv)
View attachment 20131025-GrantLog-101.txt
Steve2003
Colorado
Looks like 851.0625 was added to this system today:
FileVersion:7
-TowerInfo
System ID : 5C8
WACN : 927A7
Call Sign(s) :
Timestamp : Mon Oct 28 16:43:37 2013
-Tables
-Frequencies
"00-3600","v",851.06250,"00-3600",806.06250,0,6
"00-3998","cv",856.03750,"00-3998",811.03750,1,0
"01-3871","cv",859.38750,"01-3871",859.38750,0,0
Steve2003
Colorado
Looks like things are moving along on Westy's P25 system. Yesterday I had only logged 11 RadioIDs, today I am up to 29.
Today there seemed to be more voice grants than the previous few days. Most of them were coming from RadioID 0. My scanner will tune to the voice frequency but there is no voice (not even P25 detection). Perhaps they are doing some patch configurations? (The patched zoo talkgroups on Denver's P25 system come to mind)
I have also noticed more frequencies pop up on this system as well. All of the frequencies are part of the EDACS system they are on now (most are still active on the EDACS side).
Updated site log:
Code:
FileVersion:7
-TowerInfo
System ID             : 5C8
WACN                  : 927A7
Call Sign(s)          :
Timestamp             : Thu Nov  7 17:26:40 2013
-Tables
-Frequencies
"00-3600","cv",851.06250,"00-3600",806.06250,0,40
"00-3656","v",851.76250,"00-3656",806.76250,0,0
"00-3688","v",852.16250,"00-3688",807.16250,0,0
"00-3746","v",852.88750,"00-3746",807.88750,0,0
"00-3783","v",853.35000,"00-3783",853.35000,1,0
"00-3998","cv",856.03750,"00-3998",856.03750,1,0
"01-3871","cvp",859.38750,"01-3871",859.38750,1,43
"02-3731","d",0.00000,"02-3731",0.00000,0,0
Talkgroups logged thus far:
Code:
FileVersion:6
# Talkgroup List for this system
# Format:  Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits
# Priority Values:  0=Ignore, 1=Highest priority, 99= Lowest Priority
200,50,"T: 101 DT: 10/23/13@4:49",1383842584,"11/07/2013 @ 09:43",1382525340,"10/23/2013 @ 04:49","#000000","#000000","N",13
201,50,"T: 101 DT: 10/22/13@12:33",1383852269,"11/07/2013 @ 12:24",1382466827,"10/22/2013 @ 12:33","#000000","#000000","N",179
202,50,"T: 101 DT: 10/23/13@7:58",1383847151,"11/07/2013 @ 10:59",1382536728,"10/23/2013 @ 07:58","#000000","#000000","N",30
203,50,"T: 101 DT: 10/23/13@7:58",1383846465,"11/07/2013 @ 10:47",1382536727,"10/23/2013 @ 07:58","#000000","#000000","N",11
204,50,"T: 101 DT: 10/23/13@7:58",1382536725,"10/23/2013 @ 07:58",1382536725,"10/23/2013 @ 07:58","#000000","#000000","N",0
38501,50,"T: 101 DT: 10/25/13@8:45",1383869514,"11/07/2013 @ 17:11",1382712338,"10/25/2013 @ 08:45","#000000","#000000","N",346
38502,50,"T: 101 DT: 10/25/13@14:55",1383869509,"11/07/2013 @ 17:11",1382734551,"10/25/2013 @ 14:55","#000000","#000000","N",150
38503,50,"T: 101 DT: 10/25/13@14:50",1383863950,"11/07/2013 @ 15:39",1382734226,"10/25/2013 @ 14:50","#000000","#000000","N",24
38504,50,"T: 101 DT: 11/6/13@13:31",1383863990,"11/07/2013 @ 15:39",1383769881,"11/06/2013 @ 13:31","#000000","#000000","N",20
38505,50,"T: 101 DT: 10/27/13@13:05",1383866125,"11/07/2013 @ 16:15",1382900703,"10/27/2013 @ 13:05","#000000","#000000","N",30
38506,50,"T: 101 DT: 10/28/13@15:38",1383863811,"11/07/2013 @ 15:36",1382996304,"10/28/2013 @ 15:38","#000000","#000000","N",4
38507,50,"T: 101 DT: 11/7/13@15:40",1383864044,"11/07/2013 @ 15:40",1383864029,"11/07/2013 @ 15:40","#000000","#000000","N",3
38508,50,"T: 101 DT: 11/7/13@9:19",1383865812,"11/07/2013 @ 16:10",1383841162,"11/07/2013 @ 09:19","#000000","#000000","N",5
38509,50,"T: 101 DT: 11/7/13@16:10",1383865834,"11/07/2013 @ 16:10",1383865816,"11/07/2013 @ 16:10","#000000","#000000","N",2
38510,50,"T: 101 DT: 10/27/13@13:05",1383866351,"11/07/2013 @ 16:19",1382900708,"10/27/2013 @ 13:05","#000000","#000000","N",5
38511,50,"T: 101 DT: 11/7/13@16:11",1383865921,"11/07/2013 @ 16:12",1383865908,"11/07/2013 @ 16:11","#000000","#000000","N",2
38512,50,"T: 101 DT: 11/7/13@16:12",1383865938,"11/07/2013 @ 16:12",1383865924,"11/07/2013 @ 16:12","#000000","#000000","N",2
38513,50,"T: 101 DT: 10/30/13@12:53",1383866570,"11/07/2013 @ 16:22",1383159184,"10/30/2013 @ 12:53","#000000","#000000","N",6
38514,50,"T: 101 DT: 11/7/13@16:28",1383866937,"11/07/2013 @ 16:28",1383866919,"11/07/2013 @ 16:28","#000000","#000000","N",3
38601,50,"T: 101 DT: 10/27/13@12:59",1383866022,"11/07/2013 @ 16:13",1382900364,"10/27/2013 @ 12:59","#000000","#000000","N",5
38602,50,"T: 101 DT: 10/27/13@13:04",1383866036,"11/07/2013 @ 16:13",1382900689,"10/27/2013 @ 13:04","#000000","#000000","N",4
38603,50,"T: 101 DT: 11/7/13@16:14",1383866060,"11/07/2013 @ 16:14",1383866043,"11/07/2013 @ 16:14","#000000","#000000","N",2
38604,50,"T: 101 DT: 11/7/13@16:14",1383866075,"11/07/2013 @ 16:14",1383866065,"11/07/2013 @ 16:14","#000000","#000000","N",3
38606,50,"T: 101 DT: 11/7/13@16:14",1383866091,"11/07/2013 @ 16:14",1383866081,"11/07/2013 @ 16:14","#000000","#000000","N",3
38607,50,"T: 101 DT: 10/27/13@13:18",1383866111,"11/07/2013 @ 16:15",1382901519,"10/27/2013 @ 13:18","#000000","#000000","N",5
38701,50,"T: 101 DT: 11/1/13@15:13",1383866383,"11/07/2013 @ 16:19",1383340418,"11/01/2013 @ 15:13","#000000","#000000","N",21
38702,50,"T: 101 DT: 11/1/13@15:16",1383866398,"11/07/2013 @ 16:19",1383340580,"11/01/2013 @ 15:16","#000000","#000000","N",2
38703,50,"T: 101 DT: 11/1/13@15:16",1383866413,"11/07/2013 @ 16:20",1383340583,"11/01/2013 @ 15:16","#000000","#000000","N",2
38704,50,"T: 101 DT: 11/1/13@15:16",1383866156,"11/07/2013 @ 16:15",1383340584,"11/01/2013 @ 15:16","#000000","#000000","N",7
38705,50,"T: 101 DT: 11/1/13@15:16",1383866431,"11/07/2013 @ 16:20",1383340579,"11/01/2013 @ 15:16","#000000","#000000","N",2
38706,50,"T: 101 DT: 11/7/13@16:20",1383866447,"11/07/2013 @ 16:20",1383866436,"11/07/2013 @ 16:20","#000000","#000000","N",1
38707,50,"T: 101 DT: 11/7/13@16:20",1383866461,"11/07/2013 @ 16:21",1383866451,"11/07/2013 @ 16:20","#000000","#000000","N",1
38708,50,"T: 101 DT: 11/7/13@16:21",1383866475,"11/07/2013 @ 16:21",1383866466,"11/07/2013 @ 16:21","#000000","#000000","N",2
38709,50,"T: 101 DT: 11/7/13@16:21",1383866495,"11/07/2013 @ 16:21",1383866481,"11/07/2013 @ 16:21","#000000","#000000","N",3
38710,50,"T: 101 DT: 11/7/13@16:21",1383866513,"11/07/2013 @ 16:21",1383866499,"11/07/2013 @ 16:21","#000000","#000000","N",2
38711,50,"T: 101 DT: 11/6/13@12:15",1383866530,"11/07/2013 @ 16:22",1383765339,"11/06/2013 @ 12:15","#000000","#000000","N",6
38712,50,"T: 101 DT: 11/6/13@12:17",1383866551,"11/07/2013 @ 16:22",1383765420,"11/06/2013 @ 12:17","#000000","#000000","N",2
38713,50,"T: 101 DT: 11/6/13@12:55",1383767728,"11/06/2013 @ 12:55",1383767728,"11/06/2013 @ 12:55","#000000","#000000","N",0
38714,50,"T: 101 DT: 11/7/13@16:22",1383866591,"11/07/2013 @ 16:23",1383866577,"11/07/2013 @ 16:22","#000000","#000000","N",2
38716,50,"T: 101 DT: 11/7/13@16:29",1383866957,"11/07/2013 @ 16:29",1383866957,"11/07/2013 @ 16:29","#000000","#000000","N",0
38802,50,"T: 101 DT: 11/7/13@16:23",1383866639,"11/07/2013 @ 16:23",1383866625,"11/07/2013 @ 16:23","#000000","#000000","N",2
38803,50,"T: 101 DT: 11/7/13@9:11",1383866682,"11/07/2013 @ 16:24",1383840687,"11/07/2013 @ 09:11","#000000","#000000","N",2
38804,50,"T: 101 DT: 11/7/13@16:24",1383866696,"11/07/2013 @ 16:24",1383866685,"11/07/2013 @ 16:24","#000000","#000000","N",1
38805,50,"T: 101 DT: 11/7/13@16:24",1383866712,"11/07/2013 @ 16:25",1383866699,"11/07/2013 @ 16:24","#000000","#000000","N",1
38811,50,"T: 101 DT: 11/7/13@16:23",1383866735,"11/07/2013 @ 16:25",1383866610,"11/07/2013 @ 16:23","#000000","#000000","N",2
38812,50,"T: 101 DT: 11/7/13@16:16",1383866194,"11/07/2013 @ 16:16",1383866164,"11/07/2013 @ 16:16","#000000","#000000","N",3
38813,50,"T: 101 DT: 11/7/13@16:12",1383865973,"11/07/2013 @ 16:12",1383865941,"11/07/2013 @ 16:12","#000000","#000000","N",3
38814,50,"T: 101 DT: 11/7/13@16:25",1383866767,"11/07/2013 @ 16:26",1383866755,"11/07/2013 @ 16:25","#000000","#000000","N",1
38815,50,"T: 101 DT: 11/7/13@16:26",1383866980,"11/07/2013 @ 16:29",1383866773,"11/07/2013 @ 16:26","#000000","#000000","N",5
38816,50,"T: 101 DT: 11/5/13@10:56",1383865880,"11/07/2013 @ 16:11",1383674190,"11/05/2013 @ 10:56","#000000","#000000","N",2
38817,50,"T: 101 DT: 11/7/13@16:26",1383866819,"11/07/2013 @ 16:26",1383866790,"11/07/2013 @ 16:26","#000000","#000000","N",4
38818,50,"T: 101 DT: 11/7/13@16:27",1383866853,"11/07/2013 @ 16:27",1383866826,"11/07/2013 @ 16:27","#000000","#000000","N",2
38819,50,"T: 101 DT: 11/7/13@9:11",1383866882,"11/07/2013 @ 16:28",1383840698,"11/07/2013 @ 09:11","#000000","#000000","N",2
38820,50,"T: 101 DT: 11/7/13@16:28",1383866900,"11/07/2013 @ 16:28",1383866888,"11/07/2013 @ 16:28","#000000","#000000","N",2
Radios logged:
Code:
FileVersion:4
# Radio List for this system
# Format:  RadioID(Decimal),Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),Text Color,BG Color
1000,"TG: 1001 DT: 11/7/13@12:23",1383863517,"11/07/2013 @ 15:31","#000000","#000000"
1001,"TG: 200 DT: 10/23/13@4:49",1383865843,"11/07/2013 @ 16:10","#000000","#000000"
1002,"TG: 201 DT: 10/22/13@12:33",1382894832,"10/27/2013 @ 11:27","#000000","#000000"
1003,"TG: 201 DT: 11/1/13@9:59",1383796194,"11/06/2013 @ 20:49","#000000","#000000"
1004,"TG: 38501 DT: 11/4/13@11:55",1383610568,"11/04/2013 @ 17:16","#000000","#000000"
860023,"TG: 201 DT: 10/25/13@9:31",1383868272,"11/07/2013 @ 16:51","#000000","#000000"
860024,"TG: 201 DT: 10/24/13@9:15",1383869208,"11/07/2013 @ 17:06","#000000","#000000"
860025,"TG: 38505 DT: 10/30/13@15:06",1383869525,"11/07/2013 @ 17:12","#000000","#000000"
863023,"TG: 38501 DT: 11/5/13@10:05",1383869476,"11/07/2013 @ 17:11","#000000","#000000"
863028,"TG: 38501 DT: 11/5/13@10:09",1383846974,"11/07/2013 @ 10:56","#000000","#000000"
863033,"TG: 38501 DT: 11/5/13@10:07",1383851614,"11/07/2013 @ 12:13","#000000","#000000"
865001,"TG: 38701 DT: 11/6/13@19:09",1383790152,"11/06/2013 @ 19:09","#000000","#000000"
865011,"TG: 38701 DT: 11/6/13@12:12",1383793213,"11/06/2013 @ 20:00","#000000","#000000"
865016,"TG: 38701 DT: 11/6/13@19:21",1383790866,"11/06/2013 @ 19:21","#000000","#000000"
865107,"TG: 38701 DT: 11/6/13@19:49",1383792589,"11/06/2013 @ 19:49","#000000","#000000"
865110,"TG: 38701 DT: 11/7/13@15:50",1383864601,"11/07/2013 @ 15:50","#000000","#000000"
865122,"TG: 38701 DT: 11/6/13@20:11",1383793861,"11/06/2013 @ 20:11","#000000","#000000"
865125,"TG: 38701 DT: 11/7/13@15:44",1383864286,"11/07/2013 @ 15:44","#000000","#000000"
865200,"TG: 38702 DT: 11/6/13@19:56",1383793208,"11/06/2013 @ 20:00","#000000","#000000"
865205,"TG: 38701 DT: 11/6/13@19:29",1383791359,"11/06/2013 @ 19:29","#000000","#000000"
865208,"TG: 38701 DT: 11/7/13@16:15",1383866248,"11/07/2013 @ 16:17","#000000","#000000"
865210,"TG: 38701 DT: 11/7/13@15:46",1383864395,"11/07/2013 @ 15:46","#000000","#000000"
865212,"TG: 38701 DT: 11/7/13@15:48",1383864485,"11/07/2013 @ 15:48","#000000","#000000"
865218,"TG: 38701 DT: 11/7/13@15:54",1383864869,"11/07/2013 @ 15:54","#000000","#000000"
865219,"TG: 38701 DT: 11/6/13@19:39",1383791987,"11/06/2013 @ 19:39","#000000","#000000"
865221,"TG: 38701 DT: 11/7/13@16:12",1383865978,"11/07/2013 @ 16:12","#000000","#000000"
865222,"TG: 38701 DT: 11/7/13@15:51",1383864702,"11/07/2013 @ 15:51","#000000","#000000"
865600,"TG: 38702 DT: 11/6/13@12:28",1383864055,"11/07/2013 @ 15:40","#000000","#000000"
10117892,"TG: 1794873 DT: 11/7/13@6:54",1383832500,"11/07/2013 @ 06:55","#000000","#000000"
Steve2003
Colorado
It looks like Westminster has started to move some public works users to this system. TGID 38708 has been active for the past few days with crews discussing water/sewer repairs.
rckydenver
Arvada, Colorado
Listening just a few minutes ago I believe that the TG-38708 would be the EDAC TG of 564 shops, just heard on this channel that they need to move to the new radio.
rckydenver
Arvada, Colorado
TG-38704 was just on and calling it Standley so probably the park rangers (Standley Lake). Did mention boat ramp.
Another one from yesterday TG-38710 Confined Space-they where entering manholes.
Steve2003
Colorado
Westminster Water appears to be active on this system now:
38708 – Westminster Water - Shops / Repairs
38709 – Westminster Water - Finance Channel (meter units)
38710 – Westminster Water - Confined Space
38711 – Westminster Water - Treatment Plant (WTP)
Also add Stanley Lake Rangers:
38704 – Stanley Lake Park Rangers
I have tentatively identified several talkgroups in the ranges below:
385XX - Westminster PD
386XX - Westminster Fire
388XX - Mutual Aid Groups
rckydenver
Arvada, Colorado
Hearing Westy PD on the new system today and the EDACS is quiet (just heard that per Westy PD they want them to use the new radio). TG is 38501.
Also the FD, TG 38601-sounds like the dispatch Ch.
Steve2003
Colorado
Ok, just heard dispatch say "All units we are going to test the alert tones" on TG 38602. Shortly after I heard a series of six short beeps on the same talkgroup.
A few weeks ago I heard the techs refer to 38601 as "MAYDAY" when they were testing. My guess is 38602 is fire dispatch since they announced they would be testing tones on 38602.
rckydenver
Arvada, Colorado
I also heard those tones as well. And testing every now and then on 508,509 and 513.
Steve2003
Colorado
Confirmed talkgroups:
38501 Westminster PD-1 (Dispatch)
38502 Westminster PD-2
38503 Westminster PD Data
