jfab
Can anyone advise on the best sites to use for Longmont PD/Fire and Boulder County's tac channels?
Thanks!
Thanks!
P25 scanners are not limited to a single site, Put all the control channels in that you can hear. Put in the TGs that you want to listen to and push the scan button.
Bruce
Longmont choices:
1st Sunset
2nd Mead
3rd Gunbarrel FD
4th Thorodin
5th Bald South (Loveland)
County:
1st Gunbarrel
2nd Thorodin
Longmont choices:
1st Sunset
2nd Mead
3rd Gunbarrel FD
4th Thorodin
County:
1st Gunbarrel
2nd Thorodin
Depending upon where you are in Broomfield, you may find that VHF works just fine, and possibly better than DTRS, for both City of Longmont PD and Boulder County SO.
I say this because while Longmont PD's DTRS TAC talkgroup is very often encrypted, the VHF frequency being used for simulcast may often be in the clear. In particular, keep your ears open on the secondary channel at 151.31 and TAC1 on 151.22.
As for Boulder, they run a 3 freq VHF simulcast system for dispatch, but also run various VHF channels for tac use.
Heck, in the right spot, I can pick out Longmont VHF clearly in Commerce City. Much will depend upon where you are since Broomfield takes in a fair bit of territory with some differing terrain.
