jimmnn said:
I was a beta tester for Uniden so had one of the first in the country....
....as posted in the forum many times (by more than just me) it's an inferior radio in my opinion for $500.00.
So you didn't get yours free for beta-testing? The cost shouldn't be an issue for you if you did. And does that mean you won't beta-test for them again?
If you compared the BCD396T to the BR330T, you'll realize that a good chunk of the price is 'probably' due to the digital vocoder licensing fees.
The Pro-96 without the digital aspect is nothing more than a Pro-95 and in fact, the Pro-97 (which I also have) would be better (and probably lot more expensive) if it did have digital.
You're definitely entitled to your opinion and for the benefit of other people I have to ask:
So you're saying the Pro-96 is "so much better" for about the same price?
Let's see, off the top of my head, the "superior" features of the Pro-96:
-- Can NOT change step size for frequencies
-- Several bands have the wrong step size and can NOT be change
-- Won't decode CTCSS and DCS as it finds it without having to switch modes
-- Much bigger and heavier
-- Less info on the display about what you're monitoring
-- Much less memory readily available
-- Won't track narrow band EDACS or SCAT
-- Won't track LTR
-- Less frequency coverage
-- No computer control
-- Not firmware upgradeable (only the DSP)
-- It has had it's share of bugs that requires people to send it to the shop
-- It has had it's share of defects that also requires people to send it in
-- No I-Calls
-- No signal strength meter (at least for general reference)
-- Not as quick and direct access to a TG
-- Only one programmable search range
-- Can't Scan and Search at the same time
-- No Close Call
-- No selectable FM/NFM/WFM
-- Doesn't have and won't support trunk-tracking on the 700MHz band. ( I know you can unlock it but it won't track it and those systems are starting to pop up around the nation)
-- Can only input one Offset table through keypad on VHF/UHF systems
-- Won't track 9600 VHF/UHF systems without having some 'specific' info for Base/Offset tables that you can only get by running Pro96Com on the system you want to track.
-- The list goes on....
And that's just a quick recap, those features above are not just "gimmicks" but a necessity for many and a clear choice when deciding between the BCD396T and the Pro-96.
My main issues are audio quality and the fact it loves to lock on a control channel and not resume scanning for another, especially troublesome if your mobile but for a Golden to Lakewood commute that might not be an issue.
The audio quality definitely is not as 'level' as the Pro-96 but certainly much 'cleaner' in many instances. It's almost as loud in general (especially on digital) and I would only rate the Pro-96 a point or two higher in that department.
I haven't experienced the control channel lock "issue".
I'm still a GRE fan too (have several models including the Pro-96/2096), BUT I think Uniden deserves at least some credit for their innovation and participation in the community, which the latter we never had ever before! I also think the BCD396T is a great radio and there's a lot of bashing from people that don't even own the radio and are repeating what somebody else is saying. If I was to listen to those kind of people, I wouldn't had bought my Pro-96 when it first came out.....
Like they say your results may vary.
EXACTLY!
