Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Colorado Radio Discussion Forum
Colorado Radio Discussion Forum Forum for discussing Radio Information in the State of Colorado.
Old 04-26-2014, 1:48 PM
Question El Paso Co Medevac Ground Contact
What is the talk group for ground to Medevac helicopter contact? I have been hearing dispatchers say "Stack D", but I have been unable to identify that.
I have been able to locate their regular traffic on the Cheyenne Mtn tower, on their conventional channels and once a long time ago, on AMR Ch 2 TG 4896.
Any info would be greatly appreciated. Thank you.
Old 04-26-2014, 1:51 PM
dw2872's Avatar
Default El Paso Co Medevac Ground Contact
That is STAC-D 853.7875 MHz (156.7 PL)
Sounds like a bad TA in Fountain right now with a double chopper go. One for sure just landed on Hwy-85 in front of Valley Bowl.
Dan
Pro-106 (saving to Pro96Com), 396XT (saving audio and metadata w/ProScan), and SDR dongles
Old 04-26-2014, 1:59 PM
Yea, I am listening to that as well as the fire out in Yoder. Busy day, as usual around here.
Thanks for the info.
Old 04-26-2014, 2:05 PM
dw2872's Avatar
Yeah, and now I am hearing Wescott FD talking on their admin channel about an exercise drill they are about to participate in.
Dan
Old 04-26-2014, 2:14 PM
They are doing a wildland fire drill over off Baptist Rd with the North Group. They did that earlier this morning too. They are using C2. The Yoder fire had to use C3.
BTW, where did you find that STAC info?
dw2872's Avatar
STAC-D is Statewide TACtical - Direct
Dan
Old 04-26-2014, 2:18 PM
jimmnn's Avatar
Saying fire in Yoder is less than a 1/2 acre.
Jim<
Old 04-26-2014, 2:22 PM
dw2872's Avatar
I cannot remember where I got that from but the S either stands for Statewide or Simplex... or both
Dan
Old 04-26-2014, 2:48 PM
Maybe off the RRDB Colorado Statewide Mutual Aid Page I just found with the RR Data person for this area labeled that entry as "CO STAC".
Old 04-26-2014, 2:50 PM
dw2872's Avatar
Cool. They should probably relabel it as Statewide/Simplex TACtical - Direct (STAC-D).
Dan
Old 04-26-2014, 2:59 PM
Spitfire8520's Avatar
STAC-D used to be on the State of Colorado DTRS page and was labeled "STAC (repeater) & STAC-D (direct)" under the description for DTRS (along with the Simplex channels). It got removed sometime in the middle of 2013 and is only on the Colorado Statewide Mutual Aid page you found.
Old 04-26-2014, 3:21 PM
Thank you for that Spitfire. I programmed those 4 Simplex frequencies into my radios awhile ago. I thought I had seen them. Now I have the others as well.
