utlchris
Just buying a BCD396T and a new user I have figured out the basics of programming using the ARC software with the RR subscription. I have uploaded the state system several times and maybe I'm missing something or doing something wrong. The problem is that it appears to be loosing the CC, or Just Thornton alone. It will still pick up Adams CO so. When I program using the ARC software with the RR data base I "Select All" for the Site names, then Select "Adams County" and check the "Control Channel Only". Is there something I'm missing? I suspect I might be in a weak area too but can't figure out why Thornton may drop out and others still work or can change to scan to ID Search and it will find things under the same control channel. My remedy to this problem is to turn off the radio and back on to what it appears to find a new CC and Thornton appears to be working again. It also appears to work better if I scan nothing else than Thornton PD and FD. When I drop in Adcom SO, Brighton or something else in the Adams County area is when it usually will drop Thornton after a amount of time. Anyone have advise on this? Thanks in advance!
