In major incidents such as a wildland interface fires, multiple operations talkgroups will get assigned and units coming into the area will eventually overwhelm DTRS and start giving system busy signals due to lack of voice channels. This can be mitigated by shifting many things to fireground channels that don't need a repeated channel like staging operations, water supply, and even geographical incident divisions since they'll likely be working in close proximity. This does mean that incoming units will have inability to listen to operations as they are en route, but big incidents will likely be too busy and complicated to follow by that point.
MetCom & SMFRA will be transitioning to the assignment of simplex channels immediately upon a division assignment on wildland incidents. Cherokee Ranch & Burning Tree were both perfect examples of DTR getting busied out and it creates huge accountability & safety concerns to change radio channels while crews are operating. It is the last thing we want to do actually. Local fire ground channels are useful for incidents that stay at a 2nd Alarm or smaller. Otherwise we run into the same interoperability problems faced on operations channels. When the Metro Strike Teams & Task Forces are activated none of those units have local tactical channels. Our push right now is to assign 8-Tac, V-Fire & V-Tac channels immediately for divisions, groups, staging etc. so that all resources responding can be plugged into the operation without the need for a cache radio they may not be familiar with.
In Douglas County after the I/A and or first operational period is complete; wildland incidents move over to the IMT VHF 205.
South Metro generally has a fairly comprehensive radio usage training for their personnel and they are made aware of the benefits and limitations of an Operations vs. Fireground channel. The crew likely made a decision based on their radio needs. They were likely doing a training session at their station or elsewhere with a limited number of people and didn't want to the other crews of South Metro listening to their antics.
For a few other reasons MetCom & SMFRA prefer the use of fire ground channels for training. The big reason is it allows us to free up the operations channels which are regularly used for incidents. Also when firefighters are practicing mayday scenarios and initial radio reports it helps eliminate confusion with neighboring agencies and the media. The ESK (emergency signal key) buttons are not functional in simplex mode and that helps prevent false activations during physical training.
So why do they ask dispatch which fireground channel to use, if Dispatch can't even monitor it?
MetCom does have the ability to monitor all fire ground channels and if the training / incident is close enough to the dispatch center everything can be heard. On several occasions MetCom and the Incident Commander have communicated solely on simplex during incidents in DTC / Inverness area. Also SMFRA Incident Safety Officers self assign fire ground channels when on scene and track which FG's are in use.
Here is the breakdown of Douglas, MetCom & Littleton Fire Ground Channels which probably need to be updated in the database....
Douglas FG4 - 856.2625 - NAC 293
Douglas FG6 - 858.2625 - NAC 293
Douglas FG8 - 857.2625 - NAC 293
Douglas FG10 - 857.2625 - NAC 296
Douglas FG12 - 856.2625 - NAC 296
Douglas FG14 - 858.2625 - NAC 296
MetCom FG4 - 856.2625 - NAC 29A
MetCom FG6 - 858.2625 - NAC 29A
MetCom FG8 - 858.2625 - NAC 296
MetCom FG10 - 857.2625 - NAC 29A
Littleton FG3 - 857.2625 - NAC 29A
Littleton FG5 - 857.2625 - NAC 296
Also, in the short term at least... MetCom Ops 9 will be patched with EM Dispatch and at times EM Ops Channels. Also MetCom Ops 15 is being used in place of Metro Net for coordination between LFR Control 1 and MetCom.
