Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Colorado Radio Discussion Forum
Colorado Radio Discussion Forum - Forum for discussing Radio Information in the State of Colorado.
Old 09-19-2018, 2:14 AM
snoopyII's Avatar
Default Updated Mead Site Log
Not sure when exactly this happened, sometime in the last few months, the Mead site has gotten a few upgrades. Exact same info has been submitted for db updates.
Mead site updates:
-Site NAC has changed to D1D
-Sight Neighbors, add: 352, 355.
-700 mhz voice frequencies have increased from 4 to 8, all frequencies changed.
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : D1C
System Name :
WACN : BEE07
Tower Number (Decimal): 1-12
Tower Number (Hex) : T010C
Tower Description : Mead
Control Capabilities : Data,Voice,Registration
Flavor : Phase 1
Call Sign(s) :
Timestamp : Mon Sep 17 09:04:26 2018
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250, 1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0055","v",851.35000,"00-0055",806.35000,0,0
"00-0097","vi",851.61250,"00-0097",806.61250,0,4
"00-0227","avd",852.42500,"00-0227",807.42500,0,35
"00-0287","av",852.80000,"00-0287",852.80000,1,15
"00-0381","av",853.38750,"00-0381",853.38750,1,0
"00-0477","ci",853.98750,"00-0477",853.98750,1,901
"01-1210","v",769.56875,"01-1210",799.56875,0,0
"01-1330","v",770.31875,"01-1330",800.31875,0,0
"01-1466","v",771.16875,"01-1466",771.16875,1,0
"01-1606","v",772.04375,"01-1606",772.04375,1,0
"01-1926","v",774.04375,"01-1926",804.04375,0,5
"01-1966","v",774.29375,"01-1966",804.29375,0,7
"01-2006","v",774.54375,"01-2006",804.54375,0,6
"01-2046","v",774.79375,"01-2046",804.79375,1,7
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
105,"T0105",d1c,"00-0475",853.97500,""
108,"T0108",d1c,"00-0443",853.77500,""
124,"T0118",d1c,"00-0393",853.46250,""
313,"T030D",d1c,"00-0361",853.26250,""
314,"T030E",d1c,"00-0425",853.66250,""
332,"T0320",d1c,"00-0471",853.95000,""
352,"T0334",d1c,"00-0261",852.63750,""
354,"T0336",d1c,"01-2060",774.88125,""
355,"T0337",d1c,"01-1886",773.79375,""
356,"T0338",d1c,"01-1952",774.20625,""
361,"T033D",d1c,"00-0421",853.63750,""
Old 09-19-2018, 4:47 AM
abqscan's Avatar
DataBase Administrator
The Mead site has been updated in the database.
-Erik
I love my SBS-1eR & Mode-S Beast!
Rules and guidelines for forum post content
Old 09-19-2018, 8:12 PM
Spitfire8520's Avatar
I think the site file might not be a complete picture.
I believe Mead currently has 14 channels (10 - 800 MHz and 4 - 700 MHz). Most DTRS sites don't reveal all the 800 MHz channel that they have available to them until the site gets fully loaded with traffic.
The 700 MHz channel are usually balanced in usage and only the 4 new ones have hits. I believe that most of the 4 old frequencies were moved out to Longmont. Old site files should be removed (or archived) before generating a new log, or else Pro96Com reads in the old frequency data that might no longer be used.
I think Mead is likely using the following frequencies, but I am not in a position to do extensive logging of it to confirm.
774.04375
774.29375
774.54375
774.79375
851.35000
851.61250
851.95000
852.18750
852.42500a
852.80000a
853.38750a
853.98750c
858.08750
859.08750
As for timeline, I believe most of these changes happened last year.
Mile-High Spitfire
RadioShack Pro-106 RadioShack Pro-652 RTL-SDR
MNN-250
Old 09-19-2018, 10:05 PM
snoopyII's Avatar
This was a new install- there never was a previous log for Mead on this particular laptop. I will re-examine the log
