Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Colorado Radio Discussion Forum
Colorado Radio Discussion Forum Forum for discussing Radio Information in the State of Colorado.
Old 02-28-2008, 04:13 AM
Default Display Tag Changes
I'm seeing alot of the display tag information in the database being changed to incorrect information, especially for the Larimer County entries. I had always thought the display field was for entering the actual display description from agency radios (the channel name as it appears in the radios display).
I'm putting together a little update to switch the information to its correct values but before I do I wanted to see if there was some new policy or something that changed the meaning of the "display tag" field.
Thanks.
Old 02-28-2008, 08:56 AM
greenthumb's Avatar
Colorado DB Administrator
The display tags are no longer reflecting the channel name as it appears on the radio display. The display tag field is now used for the web import into several scanner programs and the spirit of the field is now to use the 12 characters available to best describe the talk group so that what shows up on a scanner's display is easily discernable and descriptive.
Colorado Database Administrator
Forums Moderator
Rules and guidelines for forum post content
Old 02-28-2008, 09:30 AM
Aha, that explains it. Thanks much greenthumb.
Old 02-28-2008, 09:16 PM
greenthumb's Avatar
You're welcome.
That was a fairly recent change in policy that has taken place since the beginning of the year as the web import feature was finalized. It's still a work in progress with a lot of frequencies to tag. Everything should have a tag on the trunking side and a couple of handfuls of counties to finish in conventional. After that, it's on to the task of adding location data (to just about everything) that can be imported into GPS-enabled scanners via web import.
Forums Moderator
Similar Threads
Alpha Tag Column Vs Tag Column JerryNone Ohio Radio Discussion Forum 7 02-05-2008 11:41 AM
Display tag PolarBear25 Oklahoma Radio Discussion Forum 2 01-24-2008 11:54 PM
Time For A New Scanner??? Harlock Radio Shack Scanners 9 08-05-2007 07:54 PM
250D Display Fade? Jay911 Uniden Scanners 1 10-05-2006 12:01 AM
