Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Commercial Radio Antennas
Commercial Radio Antennas Please keep discussion related to professional, commercially used antennas and antenna systems for the two-way radio industry. Topics for the use of these antennas on amateur bands are accepted here.
Old 09-26-2012, 12:17 AM
Default Decible Products DB224
I just acquired one of these MONSTERS tonight,on a trade.One I may regret.....I soldered a new PL-259 on the main feeder,leaned it up against my wood fence,got an SWR reading of over 3,on 151.820Mhz(MURS 1)(This is the 150-160Mhz antenna).After reading previous posts on here,I guess I need to clean up the connections on the dipoles,check the wiring harness(it is the rg-11/rg-83-35ohm) I never realized just how big these things are! I wonder,could'nt I take the top 2 dipoles,and mount them on another support pipe?? There is a connection there from the upper half of this antenna.Man,these things are built to take some abuse from mother nature! Built like a brick you-know-what! I love it!!!
Old 09-26-2012, 12:25 AM
mancow's Avatar
They are great and you will be amazed at the performance once it's working correctly. I have a 16 bay uhf out back as well. I can get into repeaters using just an HT that other antennas barely receive.
Old 09-26-2012, 12:37 AM
Thumbs up
Yeah,I was trying just to solder a new PL259 on,and,it was getting dark,so,I will re-do the connector tomorrow.I can just 'visualize' that antenna atop my 40ft Rohn Tower!,but,I need to go over the connections,to the dipoles,clean them up,check for water intrusion,and,sweep it with a MFJ antenna analyzer.
I have built some of the 2 element dipole arrays for other MURS stations here in town,that tuned up quite nicely.
Old 09-26-2012, 10:49 PM
Spent most of the day cleaning the dipoles,unraveling the old tape from the coax connector ends on the elements,Looks good! no moisture intrusion! re-wrapped them,took off the top half of the antenna,stood it up on a 10ft pole,ran a jumper to my SWR meter,Presto! 1.2:1.Talked to several locals around town.Great reports,Now,I will be cleaning the bottom half tomorrow.Luv this antenna! Decible makes some GREAT antenna products!
Looks like the factory used some fiberglass tape,covered with some aluminum tape to secure the wiring harness???? Anyway,I will be putting the same tape back on.Keep it original
Old 10-01-2012, 8:48 PM
Thumbs up
Completely re-built both of the triangular weather-boot junctions on the bottom half of this antenna(weakpoint)on these.The center conductors had broken free.Checked continuity on wiring harness,good-to-go,Thanks;
Teray
Old 10-04-2012, 11:51 PM
It's up,and kickin' on MURS !
