Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Commercial Radio Antennas
Commercial Radio Antennas - Please keep discussion related to professional, commercially used antennas and antenna systems for the two-way radio industry. Topics for the use of these antennas on amateur bands are accepted here.
Old 04-21-2017, 12:26 PM
toastycookies's Avatar
Default Are 1/4" Heliax connectors interchangeable?
Are 1/4" heliax connectors cable type specific?
I have a spool of Andrew LDF1-50 and am making some jumpers for repeater/duplexer/amp.
Will connectors sold for FSJ1-50 work on LDF1-50 (both 1/4")?
Specifically I am trying to find PL-259 and BNC male connectors for LDF1-50 jumpers.
Old 04-21-2017, 1:08 PM
Would this work on LDF1-50?
41SP
Old 04-21-2017, 2:17 PM
prcguy's Avatar
The standard PL-259 UG-176 adapter for RG-8X and RG-59 is a perfect fit for FSJ1-50.
prcguy
Old 04-21-2017, 2:33 PM
prcguy
Right. And I have a spool of LDF1-50.
So I am asking if I can use the FSJ1-50 connectors on my LDF1-50.
Old 04-21-2017, 3:09 PM
prcguy's Avatar
I think FSJ is about .25 dia for the shield and LDF is a little bigger at .31 or something. For LDF1-50 you would have to drill out the adapter or go the expensive connector route.
prcguy
Old 04-21-2017, 3:17 PM
prcguy
That's too bad.
Need to find somewhere to get BNC male and PL 259 that will fit on LDF1-50
Old 04-21-2017, 4:56 PM
prcguy's Avatar
BNC could be a problem but a 5/16" drill bit, a drill press and drill press vice will easily modify lots of UG-176 adapters.
prcguy
That's too bad.
Old 04-22-2017, 9:05 AM
prcguy
I may try this. Does the center pin need to be drilled as well?
Old 04-22-2017, 11:24 AM
prcguy's Avatar
No, the PL-259 part will work with a center conductor up to about 10ga and the 1/4" Heliax should be no bigger than that.
prcguy
