Go Back   The Forums > Commercial, Professional Radio and Personal Radio > Commercial Radio Antennas
Commercial Radio Antennas - Please keep discussion related to professional, commercially used antennas and antenna systems for the two-way radio industry. Topics for the use of these antennas on amateur bands are accepted here.
Old 07-24-2017, 6:38 PM
KD2DXF's Avatar
Default 5/8 wave antenna kit
I ordered a 5/8th wave over 5/8th wave antenna with the nmo ground plane kit. this will be used as a 10 watt base station antenna. I know how long the vertical antenna is supposed to be cut at, but what about the radials? ive seen a few photos which show really short radials.
Any advise is appreciated. this will be used for 469.550Mhz
Matthew | KD2DXF
If today was your last day, and tomorrow was too late,
Could you say goodbye to yesterday?
Old 07-24-2017, 7:17 PM
mmckenna's Avatar
1/4 wave length is usually the minimum. At 469.550, you'd be looking at something a bit less than 6 inches.
Old 07-30-2017, 7:53 PM
Radial length has no MAXIMUM length
Manufacturers just don't want to use more material than they HAVE to
They need to be at least 10% longer than 1\4 wavelength so in your case it would be 6.5 inches minimum length
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
