Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut.
Old 06-02-2009, 07:59 PM
motorman105's Avatar
Default BCD396XT CSP settings
Hi
I'd like to make sure my scanner settings are correct to get the best reception I can of the CSP system. I get it pretty good but I still get some motor boating or machine gunning or whatever it's called now.
I have my hold time at 1, my wait time at 0.
Does anyone have any other settings I can use? like 'END CODE" I have it on analog +digital. Is that OK or for some reason should it be set at "ignore"?
Thanks for any help
BTW I've done the latest firmware upgrade for the XT
Old 06-02-2009, 09:38 PM
awasser1's Avatar
Send a message via AIM to awasser1 Send a message via MSN to awasser1 Send a message via Yahoo to awasser1 Send a message via Skype™ to awasser1
Smile
I only have the 396D but those things u mentioned wont get rid of motor-boarding. I found the updates did the best in doing that. what number is your p25 auto going to? I forget technical name. But CSP should be like 11,12,13. And how is your signal strength? How many bars? I find if I have less then 1-2 bars I get motor boarding. I dont know how many people have this model yet.
Old 06-03-2009, 07:47 AM
I'd suggest posting the question in the Uniden forum which is monitored by the Uniden product manager for these scanners.
Amateur Extra Class ~ Scanning with BCD396XT / Pro-83
Old 06-03-2009, 09:33 AM
If you're using it while mobile your reception is going to suffer due to the fact that CSP uses a multi site system so there's a struggle between which tower to lock on to. If you're stationary and still having the problem, there's a setting you can try. I'm not sure if the 396XT has it as an option but on the 996T you can adjust how many miliseconds the scanner waits before opening the squelch when receiving a digital audio transmission. Cranking that number up to 800 or so will deal with the majority of motorboating issues though it may impact the first second of the actual audio.
Old 06-03-2009, 10:10 AM
UPMan's Avatar
Uniden Product Manager
Motor-boating (also known as "motor boarding" -- a scanner torture technique) can be prevented by setting your digital channels' audio setting to Digital Only.
Got a question? Ask it in a public forum for faster response.
My solar power station
Old 06-06-2009, 09:54 AM
Just a follow up.....
I switched the "AUDIO SETTING" to Digital Only as UPMan suggested and I haven't heard any motor boarding on Connecticut State Police or Greenwich since !!!
Thanks UPMan for jumping in and thanks to awasser1, jnewell and andy404ns for their help also!
Old 06-06-2009, 01:24 PM
Dave520's Avatar
Just a reminder that Greenwich is using both analog and digital now.
Similar Threads
BCD396XT - open/closed talkgroup settings mrhowes Uniden Scanners 6 04-28-2009 02:22 PM
Official Fire Tone-Out Discussion UPMan Uniden Scanners 643 08-31-2007 12:59 AM
CSP taking over Costilla County dispatching firescannerbob Colorado Radio Discussion Forum 1 03-20-2007 07:28 PM
What are the factory default AGC settings? powerhouse Uniden Scanners 7 12-17-2006 06:24 PM
396 AGC settings Balt area doctordave Maryland Radio Discussion Forum 0 04-08-2006 10:37 AM
