| Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut. |
06-23-2009, 01:45 PM
West Hartford Rebanding
West Hartford will finally reband Wednesday 6/24 @ 2400 hours thru 6/25 @ 0400 hours, at which time the new rebanded radio channel will take affect.
06-23-2009, 04:36 PM
Yea well at least they were smart enough to do it in the middle of the night...I hope you have a uniden scanner because if I cant figure out what to do I will be asking. This is the first one I have ever put in... BC396T
06-24-2009, 01:47 PM
The new freqs are in the database, I think?
Amateur Extra Class ~ Scanning with BCD396XT / Pro-83
06-24-2009, 06:28 PM
Yes...both are in there now. once it re-bands i am sure the old frequencies will be dleleted. I put everything in ...I will see if I get anything tomorrow.
06-25-2009, 07:48 AM
HUMMM Doesnt sound like anything happened last night!
06-25-2009, 08:17 AM
The vendor called at the last minute that they did not have the correct radio channels, so it was called off still awaiting when it will be done.............
06-25-2009, 08:24 AM
Thank you.. I have both the new and old systems in scanner so I think I am covered.
06-25-2009, 03:41 PM
Thanks for the update - same here. SNAFU?
06-26-2009, 12:42 AM
The system was switch 6/25/09 to the new channels: 853.8125 MHz, 853.2875 MHz, 852.5500 MHz, 851.8000 MHz, and 851.3250 MHz. The system will remain analog.
06-26-2009, 08:51 AM
Yup. Around 23:00 yesterday (6/25) they did a role call on fireground 4 and stated that they'd be using that channel as dispatch, ground, etc until further notice while they brought the rebanded channels fully online.
06-26-2009, 09:08 AM
Yes, I noticed 853.2875 was the control channel this morning and that it was very strong (not the typical fluctuating signal) from where I work in Bloomfield. I know the signal hasn't changed, so I can only assume it's due to cellular interference that no longer exists?? I need to monitor the system a bit more on the way home from work, etc. I wish the CSP would reband already for this reason !!!
-MarkB
06-26-2009, 11:39 AM
Exactly here too I am in Bloomfield.
06-26-2009, 11:45 AM
Funny on the 396T I put in two separate systems one with old way and one with Rebanding.. I put all freq in not control channel only. And it works both ways. Very Strange.
06-26-2009, 01:49 PM
I went out for lunch around 1:00 and found only the newly rebanded frequencies active, no control channel on the old. The control channel for this system changes daily, I think at midnight, therefore you wouldn't want to set it to control channel only.
-MarkB
06-26-2009, 11:46 PM
Yep I figured that out. Thank you..It's working now...
06-29-2009, 11:40 AM
west hartford
can somebody reaffirm the correct freqs for the system because when I had it on control channel only I saw 853.4125 come up but its not listed in the database or on this page and I seem to be missing transmissions when listing to it thanks!
06-29-2009, 03:28 PM
westhartford reband questions
does anyone know if I have to do something to my scanners to track the new west hartford freqs,and does anyone have the exact freqs for the system,? thanks! also I have the correct frqs for the system they are 852.550, 853.2875, 853.8125,851.325,and 851.8000 and mine is definitely not tracking it correctly i only hear traffic on 853.2875 and 853.8125 at this time if someone could tell me how to set my scanner properly I will be grateful or Ill have to go to see big billy at lentinis....
06-29-2009, 05:13 PM
What Scanner?? Latest Firmware? Can it handle Rebanding?
Did you select the NEW Band Plan or Custom ? If not you need to do that, as with Rebanding Not only did the Frequencies change, but the behind the scenes Motorola Channel #'s also changed.
06-29-2009, 05:51 PM
band plan
do you or anyone know how to edit yhe band plan for the bc996t scanner,which I have thanks!
06-29-2009, 06:52 PM
If u use Arc Butel software it does it automatically...couldnt tell u manually.. just d/l software u get a trial period. it will d/l all the frequencies in radio reference and put the custom plan in the system. works fine. program did it all for me. Make sure u have the latest firmware the last one dealt with rebanding.
