Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut.
Old 07-18-2009, 09:01 AM
Default need ct file if possible
anyone out there willing to share a file for ct. seems what ever I try to import from RR is messed up and incomplete. Tried for 2 days to setup a decent scan list by importing from rr with know luck. Especially the trunked systems. None of them worked at all. Maybe I'm doing something wrong. I can get them into the scanner but then I never hear anything on them. I suspect they are not set up correctly. Do I have to manually go in and set things up diifferently. If so why did I pay for a premium subscription? I don't get it.
Any help appreciated. I would love to get a plan all set up for either freescan or BCT. I live in Cromwell area but travel the stste for my job so as much of the state as possible would be great. I'm using a BCD 396T.
NX1V
Old 07-19-2009, 10:06 AM
Thanks any way, I guess I'm on my own.
Old 07-19-2009, 06:23 PM
awasser1's Avatar
Send a message via AIM to awasser1 Send a message via MSN to awasser1 Send a message via Yahoo to awasser1 Send a message via Skype™ to awasser1
Wink
I use Arc Butel with the same scanner. No problems no adjustments. The only one I had to change was when West Hartford Rebanded. Givve the people a few days to answer. They will..
Old 07-20-2009, 02:45 AM
Hi AWASSER1, and thanks for your info. Everything seems to be working now except for CSP. I downloaded and installed the whole system with no adjustments and I am hearing nothing. I have MOT Type II / p25 set. Do I need to fill in the apco25 band plan? If yes is that info here on this site? Any other settings I need to set, maybe end code, status bit? And yea, I didn't give it enough time for a response, I've never really had a problem getting help here, just a little frustration on my part trying to get this scanner programmed. I apologize.
NX1V
Old 07-20-2009, 05:40 AM
pm your email address, and i'll send you the freescan file for csp when i get home this evening.
Old 07-22-2009, 12:41 AM
awasser1's Avatar
I used Control Channel only...I dont think there's a band plan...Correct me if I am wrong. It does it automatically. If u need a band plan my BC250D shows CSP is Plan 2. Try that file and see if it works. Otherwise I can try to send you my CSP file.
NX1V
Similar Threads
NASCAR Frequencies - Verified b7spectra General Scanning Forum 30 10-29-2008 03:43 PM
Washington County PA list! nyquiljunkie Pennsylvania Radio Discussion Forum 5 10-31-2007 04:55 PM
Vacationing in Uncasville, what to listen to? UFEMTFF Connecticut Radio Discussion Forum 10 07-03-2007 03:32 PM
07 Nascar Frequencies? KG4LJF General Scanning Forum 17 03-30-2007 12:15 AM
Dexter Maine frequencies dexter Maine Radio Discussion Forum 7 01-11-2007 05:14 PM
