Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut.
Old 07-31-2009, 07:10 PM
Default tolland county
hi,
can anyone fill me in on the specifics of how tolland county works. i would like to input some frequencies but am interested in how they dispatch and operate before i do all that
Thanks!
steve
KI4UMQ
/\/\ CDM 1550LS+ VHF
/\/\ CDM 1550LS+ UHF
/\/\ HT 1250 VHF
/\/\ HT 1250 UHF
Yaesu FT 8800
Yaesu FT-60
Uniden BC-785D
Uniden BC-250D
Austin Spectra Multiband scanner antenna
Old 07-31-2009, 08:28 PM
Send a message via Yahoo to georged4997
try ctfireems.com some guys on there where just talking about tolland going back to codes.those guys
might have a answer for you.
Old 07-31-2009, 11:25 PM
awasser1's Avatar
Send a message via AIM to awasser1 Send a message via MSN to awasser1 Send a message via Yahoo to awasser1 Send a message via Skype™ to awasser1
Smile
Best way just put every frequency in there for Tolland County...Most will be fire...and listen. each town is numbered and is pretty orderly. I just listened at the beginning many years ago and caught on before these references even started. depending on where u are . there are several cross band repeaters etc...
Old 07-31-2009, 11:26 PM
awasser1's Avatar
CTFIRE-EMS.COM FORUMS - Powered by vBulletin is the correct one. google is your friend : )
Old 07-31-2009, 11:28 PM
awasser1's Avatar
try this link..gives a good overview
Tolland County Mutual Aid Fire Service
Old 08-01-2009, 12:45 PM
izzyj4's Avatar
Most Fire / EMS dispatches are handled by Station TN (the link awasser1 provided). They also dispatch for a few eastern Hartford County towns as well as East Windsor's two fire districts. Some departments like UCONN have there own dispatch centers and follow the same unit numbering system (which is common for 75% of eastern CT. The exceptions being New London and Middlesex counties)
When you hear them on the radio the units follow this patern: Unit Type - Unit Number - Department Number. For example Tolland Fire Department's Engine Tanker 1 is ET (or Engine Tank) 140, ect. Like everyone said, it takes a little time to get used to listening to them but you will be able to figure out who is going where.
Some frequencies used to listen up there:
33.80 (Dispatch only),
33.74
33.44
33.88
33.68 - UCONN Fire "22"
Tolland County, Connecticut (CT) Scanner Frequencies and Radio Frequency Reference <--- Link to database for Tolland County.
Old 08-06-2009, 04:46 AM
kb1ejw's Avatar
Send a message via AIM to kb1ejw
Default CT department numbers
If it helps, attached is a list for Eastern CT fire departments and numbers they use.
Also try these additional frequencies:
155.820 and 452.225 both repeat 33.86..
154.740 and 460.025 repeat 33.44
153.125 is used for tones (simulcast of 33.80)
Old 08-07-2009, 01:38 PM
izzyj4's Avatar
In the pdf file there are a few things that are wrong. The majority of them are the southern New London County area departments. They use a "bingo code system" where you have a letter and then a number. Example would be for Mahsantucket's (Foxwoods) are F-11, F-12, ect.
As for the rest of the Tolland, Windham, upper New London county areas wh are dispatched by TN, WW, QV and KX, the list is right on the money.
