Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut.
Old 11-01-2009, 10:26 AM
Default Csp
Is there any way that I can listen to CSP on a BC246T?
Thanks!
Old 11-01-2009, 11:10 AM
ethanhunt134's Avatar
Most of the CSP is Digital. You may be able to listen to some of their analog frequencies but I am not sure how often thoes are used. So in the most part, No you will not be able to listen to CSP. If you are looking for a good scanner that will pick up P25 you can try the Radio Shack Pro 96 or the 106 they are handhelds. I personally use the Pro 106 and have had no problems.
Hope that this helps.
Old 11-01-2009, 06:11 PM
izzyj4's Avatar
CSP harly uses the anolog frequencies, when I worked dispatch, they were mostly for tactical purposes. Your 246 will trak the system since its a standard Type 2 system but CSP transmits in digital so you wont be able to hear them.
| BCD396T | BCD996T | BC780XLT | PRO 2006 | PRO 2046 | BC560XLT | BC780XLT w/ Scanner Master remote head kit | TRS-452 | TRS-453 |
