| Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut. |
01-27-2012, 05:08 PM
c-med
Hi and you all for hleping me with 396xt and 996xt
bust need hlep with c-med pl tones
thank you
01-27-2012, 09:40 PM
Kmacinct....
01-30-2012, 03:09 PM
They are also all posted in the database for each of the five regions and statewide.
Joe "Izzy" Navin
K1JJN
Rigs: BCD396T, BCD996T x 2, BC780XLT x 2, PRO 2006, PRO 2046, BC560XLT, BC350A, Yaesu FT-7800R & VX-6R, TRS-452 & TRS-453.
01-30-2012, 07:31 PM
What is the statewide chnnels?
01-30-2012, 07:36 PM
Location: Mpls, MN. (But work in NY,CA,MI,AZ,KY,TN, And IN.)
If you are looking for the Freq. I believe it's:
155.34000 BM 203.5 PL Statewide Med Net
I also saw another tone Statewide uses 210.7.
01-31-2012, 08:19 AM
The statewide med channels are the same med channels only with different PL utilizing 210.7. They used to be widely used on the older radios when they only had four buttons on them to select the PL for what ever region you were operating in. They are still used sometimes but rarely as the newer radios used can practically every channel with the associated PL programmed in.
Your CMED in CT regions are as follows (roughly):
1 - South West - primarily Lower Fairfield County
2 - South Central - primarily Southern and North Central New Haven County, City of Shelton (Fairfield County)
3 - North Central - All of Hartford County, with some other adjecent towns from Litchfield, Middlesex and Tolland Counties
4 - Eastern - Primarily Middlesex, New London, Windham and Tolland Counties
5 - North West - Primarily Litchfield County, some towns in northern Fairfield County and the Waterbury area of New Haven County.
The MedNet is currently a base-to-base system and is totally different in usage from the standard UHF med channels. It a part of the old HEAR system prior to the implementation of the UHF MED channels (if I remember correctly).
Joe "Izzy" Navin
K1JJN
01-31-2012, 10:33 AM
Thanks, Izzy. Just a thought, why not write a wiki, or submit that info to the db? It would help the community, considering that's where I got the info.
Anyway, thanks again! have a good day.
01-31-2012, 10:36 AM
okay thank you
01-31-2012, 10:40 AM
210 203 tone
01-31-2012, 01:51 PM
I was thinking about it as I used to work at New Haven C-MED, but each region also operates differently. So I would need help from obtaining information from their operations as well. I'm a perfectionist so I really don't want to put out guesses on the other regions, I want the actual correct information there. But also I've been out of the loop since I left there in '07.
Joe "Izzy" Navin
K1JJN
02-01-2012, 06:27 AM
I can understand the accuracy issue, but understand the wiki is about colaboration and I have found [sadly with the new scanners and the hobby] that if we don't put it out there first [even if from memory] the comments are "Why is this missing", "They never have this/that".
Sometimes building the template and indicating the date of the intel, causes folks to build upon it. So many of the Federal Wiki's are built upon one little piece of info that grew into a monster
02-01-2012, 10:06 AM
Sorry for a short, insignificant, reply.... But that was perfectly stated. (Thanks for saying quicker, and better, than I could)
02-01-2012, 08:25 PM
There is a map of the EMS regions on this page: DPH: Emergency Medical Services - Committees & WorkGroups
Even though there are 5 EMS regions, there are (I believe) 13 CMED dispatch centers throughout the state. I think Southwest is the only one that covers the entirety of a region. The others are divided among multiple CMED centers.
Scott - KB1JHU
EMT-B in 138
02-02-2012, 07:12 AM
Since the question of CMED channels comes up often, I decided to modify the map from the link posted by Scott above! Hope it helps! Unfortunately, the original map is not of good quality for printing. The cities are all blurry but it serves the purpose.
Manny
N1SQB - AMATEUR- EXTRA CLASS
G.M.R.S - WQLH-214
IN GOD WE TRUST! EVERYONE ELSE, WE MONITOR.....
02-02-2012, 07:36 AM
Whats the difference between c-med and the med channels used for ambulance patches to hospital?
I know I get amb->hospital on 463.0500 pl 192.8 here in litchfield.
I dont see that listed on the map so maybe thats not c-med?
02-02-2012, 10:44 AM
The frequencies listed on the map are for the regional medical direction centers in the 5 regions of the state. As Scott stated, there are 5 regions but about 13 actual centers. CMED stands for Coordinated Emergency Medical Direction. This is where the ambulances check in so to speak and are directed to (patched in) via a medical channel where they can talk directly with the hospital they are heading to for advance notice. The 463.000-463.175 med channels are all used in CT. but with different PL tones.
Manny
G.M.R.S - WQLH-214
02-02-2012, 10:56 AM
That is a patch channel (Med 3) and is part of the CMED system. There are Coordination channels and Patch channels. Some regions just give out Med channels assignments from the ordinary FD/EMS channels. Some regions require going to a Coordination channel and get a Patch channel assigned from there.
The frequencies listed with the map are coordination channels used in each region.
chris
02-02-2012, 11:08 AM
Add to add on to Manny's previous post (and good find on the "new" map), each region has either one or multiple dispatch centers to co-ordinate the ambulance to hospital communications. South West, (now located in Bridgeport for the past several years after moving from Norwalk), South Central (New Haven) and North West (Hartford) all have one centralized dispatch center. North West has two (North West Public Safety in Prospect and Litchfield County Dispatch [LCD]) while the Eastern region has 6 separate dispatch centers (Willimantic Switchboard [WW], Colchester [KX], Valley Shore, Waterford ECC and Groton Fire Alarm) utilized for co-ordination. These centers also have primary dispatch for various ambulance and fire agencies as well. For example Ansonia, Derby, Bethany, and Shelton EMS are dispatch South Central, so they don't have to sign on MED 10 they are responding. Since New Haven Fire has their own dispatch and they utilize AMR fro transport, those units sign on MED 10 when they are responding, arriving, going to the hospital, ect. When going to the hospital, the C-MED dispatcher assigns a med channel that is utilized for the closest hospital or they can "hook up' a different med channel to the hospital radio if they are coming from a distance where the local MED channel tower cannot revive them.
MED 9 and 10 are the "dispatch channels" and 1 through 8 are used for ambulance to hospital communications. In some areas MED 4 and 2 are also utilized as dispatch channels if 9 & 10 are being utilized by another center that is too close.
Joe "Izzy" Navin
K1JJN
02-02-2012, 11:31 AM
Izzy, you listed 5 for eastern but mentioned that there are 6. Where is the 6th one buddy? Ya left us short..LOL...
Manny
G.M.R.S - WQLH-214
02-02-2012, 02:07 PM
Hopefully I got it all right! I obviously did not create the map, only modified the original wording on the bottom. I added the boxes and arrows according to what Izzy stated in the earlier post. I modified the compass using clip art and adding the stace of CT. blue map in the center. It prints out really nice and very legible!
Manny
