are you refering to naugy police or fire dept-i dont listen to the police but when its quiet ill unlock the fire dept to listen in,they used to be very busy with at least 1 structure a week back years ago-it got quiet since then but when they get a job its a decent size one.the great think is they use mutaul aid from beacon falls and waterbury and everyone goes home safe.
What is this NAC 88 Digital P25.of which you speak? I have had this frequency in and it used to work. Do I need to re-enter it using the talkgroup button, instead of conventional button? I have only ever used the conv. button. I have programmed most everything with Win 500 and RR. This has worked so well I have stayed at noob status.
If you have a digital capable scanner, program that frequency as a conventional (not trunked), digital (not analog) channel. Some digital scanners cannot use the NACs (digital equal of PL/DPL) much like the early scanners could not take PL/DPL.
I always maintain it is much better to first learn how to program the scanner without relying on software or RR download. That way you get familiar with the basic operation of the radio and can edit channels to change parameters without being slaved to the computer or web. After you have basic skills, then hit the software and the internet files.
I I have a Pro-106 and the book and from what I see, doesn't say anything about a digital option after pushing the conventional button. (F2) Pushing the conventional button (F2) didn't offer the option,either. It looks like you said to NOT use the TGRP (F1) button. thanks
Thanks for pointing out that Naug stopped encryption.
Feel free to ask me, if anyone has this same problem. I know almost nothing about scanning, but can read, understand, and now answer my question in probably ten seconds.
