Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut.
  #21 (permalink)
Old 12-01-2012, 1:16 PM
what kind of scanner do I need for that Connecticut transit will my home Patrol work and how can I program it ill the 396 work as well someone listen out for my bus number is 22 let me know what it comes up as I will play with the radio at 530
  #22 (permalink)
Old 12-01-2012, 1:39 PM
firerick100's Avatar
i have not seen anything about the transit in the data base with freqs and talkgroups, and would this cover the buses in waterbury
  #23 (permalink)
Old 12-01-2012, 2:35 PM
cg cg is offline
The system is the CSERN
Connecticut Statewide Emergency Radio Network (CSERN) Trunking System, Varies, Connecticut - Scanner Frequencies
It should cover Waterbury but may not be active there yet. You would try using the Wolcott Site, CC is on 774.58125.
The 396 will work if you do a custom search between 769 and 775 using CC Only and 6.25 steps.
chris
  #24 (permalink)
Old 12-01-2012, 4:00 PM
chris
thanks chris they dont have that contro, channel 774.5821 loisted yet on the database but ill put it in and see what i hear
  #25 (permalink)
Old 12-02-2012, 5:37 PM
bluefox2163's Avatar
Default tdma
can any scanner monitor a p25 tdma system?
  #26 (permalink)
Old 12-02-2012, 5:48 PM
cg cg is offline
APCO Project 25 - The RadioReference Wiki
Once again, first return on an internet search.
chris
  #27 (permalink)
Old 12-02-2012, 6:07 PM
scanningisfun's Avatar
Send a message via MSN to scanningisfun
chris
This is what I do also with my 396. It works quite well when traveling through different states. I have two 800 MHz CC-Only searches, and one 700 MHz CC-Only.
Jacob
  #28 (permalink)
Old 12-03-2012, 5:37 AM
Default tdma
can a scanner monitor a p25 tdma system?
  #29 (permalink)
Old 12-03-2012, 8:28 AM
cg cg is offline
Try searching for an answer, or try reading the answers provided. Once again, here is a link that has that information. You may have to read or scan down as the answer is not on the first line of the link.
chris
