| Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut. |
11-26-2012, 10:19 AM
State 700Mhz System
Had some time today and caught the following talk groups on the 700 fairfield county system.
80176--80192--80208--80224-80240--80304
All key ups and some blowing in the radio.
Then searching the 700 mhz range 769-806
I was getting all kinds of stuff on 791.8625 P25, troop F troopers talking, Troop A troopers talking, troop g dispatch and troopers, marshals talking, talk of bridge inspections on 684, person on highway 95 exit 14 and on and on. It was like a scanner of the CSP on search...Loud and clear in prospect on the hill
11-26-2012, 11:06 AM
CT State 700Mhz System
Besides 791.86250 I heard them on 791.803125, 792.012500 and 792.015625
I dont know if this is a trunk system
11-26-2012, 11:18 AM
You are probably hearing images on a GRE/RS scanner.
Tom
11-26-2012, 8:24 PM
The legit CSERN activity will be 769-775MHz. Towers are going online in different parts of the state now. I have logged several in the Greater Hartford area.
P25 systems are different from the older Motorola systems in that they don't need 16 bit TGID separation, so instead of 4095 TGIDs there can be 65535. To get the correct TGIDs on the new system, take the ones you are getting and divide by 16.
80176=5011
chris
11-29-2012, 6:42 PM
80176=5011
chris
What sites/control channels did you log? I hooked my 396XT up to Unitrunker and was able to find an alternate CC for site 30 (772.23125). I was also able to find a new site not listed in the DB, but was listed as one of site 30's peers. That site is site 27 (Have not converted CC using band plan, CC was 01-1968). I haven't submitted the info.
Jacob
11-29-2012, 6:47 PM
CG,
Thanks so much for that info
really appreciate it
FYI below is what i was able to figure out using the magic numbe divide by 16
2051 127 GOVSEC -19 Connecticut P25
1003 50 SW-COM-2 -19 Connecticut P25
2047 115 BCI-E -19 Connecticut P25
4002 *ID 4002 -19 Connecticut P25
2005 117 SNTF 2 -19 Connecticut P25
2011 123 CTS -19 Connecticut P25
3087 *ID 3087 -19 Connecticut P25
2043 118 SNTF-E -19 Connecticut P25
* ID Wildcard -15-19 Connecticut P25
4059 *ID 4059 -19 Connecticut P25
4001 *ID 4001 -19 Connecticut P25
303 06 G-DISP 2 -19 Connecticut P25
301 05 G-DISP 1 -19 Connecticut P25
11-29-2012, 7:31 PM
Eagleye,
Are you seeing them on the new system or those 79x.xxxx freqs? Those are images from the existing CSP system. You would need to search 769-775 and, if you have a scanner that will display NACs, look for $3A8 for a NAC.
On the Talcott site, there has been one or two hits from CTS on 2011 but everything else has been CT Transit traffic.
There are 5 active sites and 1 inactive site that I have logged using Pro96Com.
21 - original network in SW CT
22 - shows up as neighbors but indicates as inactive
27 - 774.30625 - I suspect this may be Jon Tom in Glastonbury
28 - Talcott Mtn, Avon
29 - Wolcott (maybe West Peak but strength I84/I691 area indicates likely Wolcott)
30 - 773.33125 - no guess as to location yet
chris
11-29-2012, 9:20 PM
I got a question or two. WTH are you all talking about? That was rhetorical ! Next question is will I be able to just use the software and the site to load things up whenever everything gets settled? Oh I can contribute an observation from today. I am deep into Newington, on the Berlin TP. and again I hear Prospect Fire. I have four bars with my Pro 106 and 800 mgz ducky. So I plug in my window mount ant. that is un-used and get three bars.
11-29-2012, 9:41 PM
Csp 700mhz
Chris,
again thanks for the info you are the man!!
I have a PSR-500 that i configured a wildgroup object with CSERN parameters
the SYS object has these frequencies and while i was in Bridgeport and Greenwich i picked up the following talkgroups far down
771.231250
771.781250
774.206250
769.531250
770.081250
770.581250
Talks groups I picked up with my wildgroup
4002 *ID 4002
3087 *ID 3087
4001 *ID 4001
4059 *ID 4059
i also picled these frequencies while i was having a snack at Mcdonalds I95 exit 5 i 'm most
certainly these belong to CSP
791.803125 P25 NAC 165
791.862500 P25 NAC 165
792.012500 P25 NAC 165
792.015625 P25 NAC 165
11-29-2012, 10:06 PM
Originally Posted by eagleye
Chris,
771.231250
771.781250
774.206250
769.531250
770.081250
770.581250
4002 *ID 4002
3087 *ID 3087
4001 *ID 4001
4059 *ID 4059
The NAC you listed is also used on the 800 system from what I have seen.
Jacob
11-29-2012, 10:46 PM
771.231250
771.781250 ACC for the original 3A8 system, Site 21
774.206250 PCC for the original 3A8 system, Site 21
769.531250
770.081250
770.581250
4002 *ID 4002 = 64032 - CT Transit TG
3087 *ID 3087 = 49392 - Juvenile Prisoner Transport TG
4001 *ID 4001 = 64016 - CT Transit TG
4059 *ID 4059 = 64944 - CT Transit TG
These are all images from the regular CSP system
Curious if you have figured out which CT Transit Division those TGIDs belong to. I am getting CT Transit in a different range on the 700MHz system in Greater Hartford (5xxx).
chris
11-29-2012, 10:57 PM
So we are able to monitor these now or are they simulcast? also I thought the 700 system was goinf to be phase 2 or tdma and not monitorable I had the freqs that were originally licensed in my radio but took them out
Uniden 396XT, Pro 163, BC345XT, BC700A, Pro 528, BC III (UHF) PRO 2018, Regency HX1000, TYT Dual Band TH-UVF1 (2), Beofeng UV-5R (2), Pro-197, Motorola HT750 X2 (VHF/UHF), CDM 750, CDM1250
11-30-2012, 5:13 AM
The 700 system is for now FDMA. So you can listen.
The only public safety TDMA in the state for now is going to be New Britain but the state system can do it at some point in the future.
For the system I caught TG 5012 yesterday in stamford and they were saying testing the BUS 2 channel and they said your loud and cear on bus channel 2.
Advanced System Key Master
11-30-2012, 8:03 AM
from monitoring the 64xxx TGs on the CSP system, may be something like:
Talkgroups:
50x0 - ATG
50x1 - Bus 1
50x2 - Bus 2
50x3 thru 50x8 - unknown
50x9 - Supervisors/Emergency
Districts:
501x - from APX post, Stamford or perhaps New Haven?
503x - New Britain
506x - SEAT (Southeast CT)
They are using the statewide license so there is no additional licensing unless they need additional channels.
If I recall, New Britain had specified Phase 1 and the capability to go to phase 2 in the RFP, didn't realize they are going to start out on 2.
chris
11-30-2012, 9:37 AM
COOL Thanks
11-30-2012, 9:06 PM
771.231250
769.531250
770.081250
770.581250
chris
I was hearing some chatter on 5032 off of the Talcott site while on the way to see Lincoln.
Jacob
11-30-2012, 11:19 PM
hey guys how do I program the homepatrol for Connecticut transit I work for dattco but drive a state bus I have a 396xt program conventional it worked okay will the 700 work for the 396xt and 996xt I work tomorrow bus a22 if you hear that I see scan new england.net has all the information so can you guys help me out and I will help you out I know the frequencies the sites and a talk group
12-01-2012, 6:37 AM
new britain
do you mean no scanner can monitor a tdma system? and what does tdma stand for?
12-01-2012, 9:06 AM
You need to put the CSERN system in manually as it will not download when a HP database update is done.
The easiest thing would be to create a favorite list for it and upload it that way. Be sure to add a TGID or it will not work. Also put it into ID search rather than ID scan.
chris
