Quick question, when inputting sub fleets for the fire dept, I don't monitor the other dept.'s, my Uniden bc8T shows the subfleet as 000-01 but my BCT15X shows it as 000-1, is there really a difference? Thanks.
Are you picking up their communications after you programmed it? if so then it should be all good i dont really know if it matters i had mine programmed for me.
if thats the truth,then lets sit back and see how many people go out and buy this scanner just to monitor new britan,i cant pick them up from my area,but they do get alot of action and im sure some people do buff there.
Their RFP called for a P25 system with the ability to upgrade to the P25 TDMA. Figured they would start out at the lower level they once it was up and running try the TDMA. Either way, long overdue.
