Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum - Forum for discussing Radio Information in the State of Connecticut.
Old 03-11-2014, 1:42 PM
Smile CT Transit
Does anyone out there know the new frequencies for CT Transit in the New Haven area. RR has the new frequencies for Hartford and New Britain but nothing for New Haven. I believe they are digital now. The old frequencies for CT Transit in New Haven are no longer in use. The database needs to be updated with the new digital frequencies for New Haven.
Old 03-11-2014, 4:56 PM
awasser1's Avatar
did you try putting anyone the New Haven Area CSPERN freq in without on search instead of scan for talkgroups to see if CT Transit appears?
Old 03-11-2014, 10:25 PM
cg cg is offline
You would need CSERN and not CSPERN
For New Haven, try Site 20 or 21. You can do a CC only search from 769-775MHz and see what you get.
chris
Old 03-12-2014, 10:02 PM
awasser1's Avatar
sorry i always get those acroymns mixed up. I was thinking the correct one
chris
Old 03-14-2014, 1:43 PM
Smile CT Transit
Can't search with my Home Patrol so I tried searching with my 396xt with no luck. The channels are out there somewhere but no one seems to know them. Used to pick them up very easily in the past on UHF. Thanks for your help anyway. I'll keep trying.
Old 03-14-2014, 8:57 PM
I listened to them today for a while, not very exciting. The Database has all the info correct. They come in loud and clear in Hamden at Walmart
Advanced System Key Master
Old 03-14-2014, 9:03 PM
awasser1's Avatar
are there any new talk groups for the buses in New Haven if that was what you heard?
Old 03-15-2014, 12:07 PM
Smile CT Transit
Thanks for the info but can I ask where you see CT Transit for the New Haven area in the data base? I only see Hartford and New Britain listed under CT Transit. I think I'm missing something here.
Old 03-15-2014, 12:54 PM
firerick100's Avatar
So has anyone monitored the bus drivers conversations,it has to be somewhat boring unless there is an incident on board ,I looked at the busses in Waterbury and do not see any antennas on them so I am wondering if they have radios or not
(1)396T( 3) 996 xt's(2) 396 xt's (1) Ht 1250 (VHF)(1)Ht 1550 xls (UHF)
(1) HT 1550 xls (vhf)(1)MTS 2000 type 3 (1) Motorola XTS 3000
Rickbryce@twitter
www.rescue9photography.com
Old 03-15-2014, 1:19 PM
Smile CT Transit
They always had radios in the past. When they were on UHF I would listen every morning especially in the winter to find out which streets in New Haven were passable after a snowstorm. I just don't know if they are digital now or on some other frequency that I can't seem to find. I don't see them listed anywhere in the data base. They stopped transmitting on the UHF frequency shortly after moving into their new building on State Street in New Haven. Their old frequency of 452.725 listed in the data base under Transit in New Haven County is no longer active and hasn't been for a long time.
Old 03-15-2014, 8:44 PM
cg cg is offline
Monitor the 700MHz TRS http://www.radioreference.com/apps/db/?sid=7196
If you are using the Home Patrol, you already have it programmed in. You could also do a CC only search of the 769-775 range.
Not exciting but a good way to monitor the system for future users.
chris
Old 03-20-2014, 10:45 AM
OK I see the issue, You have to listen to the P25 CSERN TRS to listen to CT transit, they are digital.
TGs as follows
Bus-1 4011
Bus-2 4012
Bus Repair- 4014
Old 03-20-2014, 2:23 PM
cg cg is offline
This is what I have determined from my monitoring:
All the CT Transit TGIDs on CSERN are 50xx. Each division has 10 talkgroups. Hartford is 500x, Stamford is 501x, Waterbury is 502x, and New Britain is 503x. South East area Transit (SEAT) is assigned 506x but is still on the 800MHz CSP system and is using the old 40xx TGIDs.
50x0 - ATG
50x1 - Bus 1
50x2 - Bus 2
50x3 - Supervisor
50x4 - Maintenance
50x5 - Facilities
50x6 - unknown
50x7 - unknown
50x8 - unknown
50x9 - Emergency
chris
Old 03-21-2014, 1:41 PM
Smile CT Transit
I guess the New Haven area is not in the database because my Home Patrol is not picking up any transmissions. Only Hartford and New Britain are in the database.I will try again with my 396XT. Thanks for the info. I guess nothing is simple anymore.
Old 03-22-2014, 11:22 AM
w1kne's Avatar
NewEngland DB Admin
I added the submitted TGs to the DB today. If there is anything else missing, let me know.
Thanks,
-- Mike
Mike Fitzpatrick
Southern New England DB Administrator
Broadcast Transmission/RF Engineer
Old 03-23-2014, 8:42 PM
I just saw that a ton of talk groups were added on scern. Uasi channels in Fairfield county ,
Rickbryce@twitter
Old 03-24-2014, 9:49 AM
There was activity on ids 5027 and 5037 today
Rickbryce@twitter
Old 03-30-2014, 9:35 AM
Smile CT Transit
Still haven't recieved a thing on the New Haven bus channels 4011 or 4012 that were recently uploaded to the database.. Has anyone picked up anything on these two channels? I'm using two scanners and nothing on either. Maybe its my location.
Old 03-30-2014, 1:20 PM
cg cg is offline
Likely nothing wrong with your scanner, 64176 (4011) and 64192 (4012) were only temporary talkgroups on the 800MHz CSP system. Same traffic moved to 5011 & 5012 TGs on the 700MHz CSERN system.
chris
Old 03-31-2014, 1:34 PM
Smile CT Transit
I'm not picking anything up on 5011 or 5012 either. Is anyone actually picking up New Haven on these talkgroups? Once again, maybe its just my location. Not quite sure.
