Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut.
  #441 (permalink)
Old 05-24-2011, 4:06 PM
Chas486's Avatar
Has anyone programmed a BCD996T (with APCO-P25 card) or BCD996XT with the new CSP rebanded freq's? I have downloaded it from RR, locked out a few sites\troops I don't want to listen to and uploaded it to both of these scanners, but still don't pick them up. Worked prior to reband, but now I get nothing. Any ideas would be greatly appreciated.
Uniden BCD996T (firmware 3.02.00), Butel ARC-PRO V3.2.004, Proscan V4.4.7
Uniden BCD996XT, Butel ARC XT PRO V1.7.2
  #442 (permalink)
Old 05-24-2011, 4:12 PM
UPMan's Avatar
See my post 2 or 3 up. Although some of the sites had their frequencies updated for the rebanded set, a few did not get their rebanding flag set. So, any scanner software that automatically loads from RRDB will apply the incorrect band plan. Manually adjust the sites to all be rebanded and see how that works out.
UPDATE: I see that my submission has been "owned" now, so it will likely be fixed tonight.
Uniden Product Ninja
Professional Scanner Developer
  #443 (permalink)
Old 05-25-2011, 2:33 PM
Chas486's Avatar
I attempted to change the non-rebanded channels back to normal from a P25 system with no luck. I deleted every site except Troop G, A & I and all channels (ID's) except the same. Here is my config:
System - MOT Type 2
System Name ID Scan / Search Record Delay I Call Status Bit End Code Digital End Code Emerg. Alert Emerg. Alert Level
CT State Police ID Scan Off 2 Sec. Off 0 Detect 1 Off Auto
Site - Frequencies MOT Type 2 P25 (System - CT State Police)
Site Name Quick Key Startup Key Lockout Hold Time Att. Mod. Ch Chan Only P25 Mode P25 Level GPS Enable Latitude Longitude Range
Troop G None None 0 2 Sec. 0 Auto 1 Auto 8 0 41.1725 -73.4342 30 Miles
Frequencies (System - CT State Police Group - Troop G)
Frequency Lockout
853.7500 0
853.2000 0
851.7125 0
852.5875 0
852.2000 0
853.5000 0
Troop A & I None None 0 2 Sec. 0 Auto 1 Auto 8 0 41.559561 -72.946781 30 Miles
Frequencies (System - CT State Police Group - Troop A & I)
Frequency Lockout
853.3125 0
852.7000 0
851.6375 0
852.1375 0
851.2750 0
Group - TGID's (System - CT State Police)
Group Name Quick Key Lockout
State Police - W None 0
Channels (System - CT State Police Group - State Police - W)
Channel Name TGID Audio Type Record Lockout Alert Tone Alert Level
01 A-DISP 1 48 Digital 0 0 Off Auto
02 A-DISP 2 80 Digital 0 0 Off Auto
05 G-DISP 1 4816 Digital 0 0 Off Auto
06 G-DISP 2 4848 Digital 0 0 Off Auto
State Police - C None 0
Channels (System - CT State Police Group - State Police - C)
21 I-DISP 1 6416 Digital 0 0 Off Auto
22 I-DISP 2 6448 Digital 0 0 Off Auto
What am I doing wrong?
  #444 (permalink)
Old 05-25-2011, 2:36 PM
UPMan's Avatar
CT state police aren't on a P25 system. Sites should all be Motorola Type II Custom and need to have the rebanding band plan entered.
  #445 (permalink)
Old 05-25-2011, 6:42 PM
Chas486's Avatar
UPMan, first, thanks for all the help. Second, as your name states - I am UP MAN! Thanks again
  #446 (permalink)
Old 05-26-2011, 12:06 AM
awasser1's Avatar
Send a message via AIM to awasser1 Send a message via MSN to awasser1 Send a message via Yahoo to awasser1 Send a message via Skype™ to awasser1
Easiest way is make them control channel only option. And then take the control channel and subtract 15 mhz from the original freq. It took 5 seconds for me to program the whole thing....
Originally Posted by chas486 View Post
has anyone programmed a bcd996t (with apco-p25 card) or bcd996xt with the new csp rebanded freq's? I have downloaded it from rr, locked out a few sites\troops i don't want to listen to and uploaded it to both of these scanners, but still don't pick them up. Worked prior to reband, but now i get nothing. Any ideas would be greatly appreciated.
Uniden bcd996t (firmware 3.02.00), butel arc-pro v3.2.004, proscan v4.4.7
uniden bcd996xt, butel arc xt pro v1.7.2
  #447 (permalink)
Old 05-26-2011, 12:08 AM
awasser1's Avatar
Is this Paul? got any more things for me to test? happy to do that for you anytime.
  #448 (permalink)
Old 05-26-2011, 1:24 AM
Lynch_Christopher's Avatar
Send a message via AIM to Lynch_Christopher Send a message via Skype™ to Lynch_Christopher
Per your instructions I went ahead and checked the re-banding flag for all of the sites except ERV1 and ERV2. Let me know if you guys have any problems and I will make the appropriate changes.
If anybody has confirmed the frequencies for the Glastonbury site I will go ahead and add those to the database.
Christopher Lynch
RadioReference.com Database Administrator for CT,MA,NH
  #449 (permalink)
Old 05-26-2011, 6:10 AM
cg cg is offline
Glastonbury was a site that was discussed in a FCC document. Someone took a posting on the forum and submitted it without monitoring. The number 43 for Glastonbury refers to the physical Site number that is assigned to each location with CSP TRS equipment.
As of now, there are 17 sites that can be found via TRUNK88/UniTrunker (#'s 1-17). Site 17 has no location yet but is likely an Intellipeater somewhere in Site 5's area as that is the only Site that lists it as a neighbor. There is also a Site 18 that I have seen only once via TRUNK88 as a neighbor to ERV Site 13 at a UCONN game. I was not able to monitor the frequency listed by TRUNK88 as a CC.
chris
  #450 (permalink)
Old 05-27-2011, 4:54 PM
awasser1 I sent you a PM
Jay Mac
HFD
  #451 (permalink)
Old 05-28-2011, 8:47 AM
ecps92's Avatar
Default OT : Comment about submissions
Which explains why there is so much in the RRDB w/o PL / DPL or NAC's
There should be No Rush to make submissions w/o Verification.
Chris has done So Much on the CTSP Rebanding. Who will be the next State in New England. RI ? or MA ?
chris
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
  #452 (permalink)
Old 06-10-2011, 4:31 PM
Default Works!... sometimes
HI,
I spent a few days reviewing the 23 pages listed above, and finally got my 996T working (I think)...I took the same file that I used in the 996T and uploaded it to my 396T (after doing the firmware update)...
The 396T hears nothing... should it work?... I am using Freescan for up/downloading.
Given my uncertainty as to whether I actually got it right on the 996T, am I correct in assuming that if I (subscribe, then) download the current CSP file in csv format, that I can then upload using Freescan into the 996T and 396T and have 2 working scanners? It appears like the Uniden-described band plans for rebanding would be a part of the file from RR.
Do I have any idea of what I am talking about?
Thanks, Ed
  #453 (permalink)
Old 06-12-2011, 9:18 AM
cg cg is offline
Programming the rebanded CSP consists of several steps:
- Update the scanner if necessary
- change the bandplan to a rebanded bandplan
- change the old 866-869 MHz channels to 851-854 by subtracting 15 MHz
chris
  #454 (permalink)
Old 06-24-2011, 12:15 PM
When using freescan, make sure you select MOT/Custom reband type ii.
You have to do this manually by clicking on "site type".
  #455 (permalink)
Old 06-24-2011, 8:33 PM
Junior08's Avatar
Would it be possible for someone to post a screen shot of a Freescan file for CTSP properly programmed? I can usually monitor them under certain conditions and would appreciate it, thanks.
Mark,
www.scan-ne.net moderator
  #456 (permalink)
Old 06-26-2011, 9:39 PM
I did a fair amount of listening on the way down last Thursday. Lousy weather kept the CSP and locals busy much of the afternoon. The rebanded set up worked well in my 996XT and I don't think I missed any voice traffic. I got caught up in that horrendous traffic jam on the Merritt and heard a lot of traffic related to the fatal in Stamford. For some reason I didn't have the Stamford trunk programmed in, probably because I thought it was encrypted, but only a few channels actually are. That's been corrected so I should be able to hear them on the way back.
  #457 (permalink)
Old 08-31-2011, 9:04 AM
cg cg is offline
the only one I know off the top of my head that needs to be confirmed is Farmington PD F2.
I heard Irene activity on 8TAC92 so those are up on the new freqs ini CT.
chris
  #458 (permalink)
Old 08-31-2011, 7:33 PM
chris
The licensing is there, although I dont have the info in front of me.
Crime doesnt pay because radio waves are faster than cars!
  #459 (permalink)
Old 09-01-2011, 9:27 AM
cg cg is offline
It is updated according to the FCC but haven't confirmed it by monitoring yet. I have no reason to think they have not changed over though. I don't know the coverage so I might be listening for a signal that isn't there.
chris
  #460 (permalink)
Old 09-23-2011, 8:21 AM
Just a refresh to keep up top...
