Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum - Forum for discussing Radio Information in the State of Connecticut.
Old 03-05-2017, 5:31 PM
Default City of Hartford EDACS System
Hi. I'm in Canton, about 15 miles from Hartford. I haven't heard anything from the City of Hartford EDACS system on my Uniden 536. I was assuming that the signal wasn't strong enough to reach me, since i'm in an apartment using a telescoping whip antenna. But i just discovered that the system doesn't appear to be in the full database on my 536. I'm using a range of 30 miles, and i have a recent database update from Radio Reference. Any help would be appreciated.
George
Old 03-05-2017, 5:32 PM
Try re-downloading the system. I heard it fine in simsbury on portable
"Radio"
Old 03-05-2017, 5:37 PM
Try redownloading the system. Double check that the talk groups are correct. I can here them fine on my portable scanner in simsbury inside a building at full 5 bars
"Radio"
Old 03-05-2017, 6:29 PM
PJH's Avatar
PJH PJH is online now
Global Database Admin
Its hit or miss. The coverage is concentrated for the city area. When I lived nearby, the signal would come and go depending on conditions.
As they say, your milage will vary.
If you are not already, adding an external (aka roof antenna) and good antenna cable may help you out. If its sitting on a desk inside the house, you loose a lot at the higher freq's.
If mobile, use a good quality multiband/scanner antenna.
The guys at Lentini's in Berlin can help you out.
If you have received a PM from me about a submission, kindly reply within 5 days with requested information or your submission may be rejected. Thanks!
Old 03-05-2017, 7:00 PM
Hear it just fine in Wethersfield but sometimes they decide to switch to a fire ground freq. You can always monitor the Vhf 154.3100
Old 03-06-2017, 11:29 AM
Canton may be a bit too far. I'm on the New Britain/Newington line and like PJH says it can be hit or miss, even at my location. The fire comes in strong on 154.310.
Old 03-07-2017, 3:02 PM
Thanks everybody, but i don't think it's a distance/antenna problem. The City of Hartford system isn't showing up in the full database on my 536, or my 436, even though it is showing on the RadioReference database webpage. And I have installed the recent database updates.
Is anybody able to hear City of Hartford on a Uniden 536 or 436? Thanks.
Old 03-07-2017, 3:29 PM
Edit profile, turn on monitor and download?
Old 03-07-2017, 4:02 PM
PJH's Avatar
You will need to increase you "range" setting in the scanner. The system is ranged for the city limits. If your location is well outside of those limits it will not be loaded.
Updating the x36 scanners is also a two step process. First "update database". When that is done then you must "write to scanner".
Old 03-07-2017, 5:21 PM
Thanks, PJH. I have the range set to 30 miles, which is certainly farther than the distance from Canton to Hartford. And i have been doing the "write to scanner".
Shouldn't the full database on the Uniden 536 include everything in CT, regardless of my zipcode?
Old 03-07-2017, 5:51 PM
I have Hartford on my Uniden 536. You should be getting the whole Hartford system and not just part of it. I would make up a favorites list with just Hartford. That way there is no need to set any range. If you don't hear anything take a drive with the scanner towards Hartford. If you start picking them up as you get close you will know your location is out of range. I'm not too far from Hartford and they are not very strong at my location. As for the full database it should include everything in CT and beyond.
Old 03-07-2017, 6:10 PM
cg cg is offline
It is in the download. I just verified it in my latest one. You should be able to view it in Sentinal and figure out if you Avoided it or need to change a setting.
Old 03-07-2017, 6:12 PM
cg cg is offline
I never use the Zip Code mode. Favorite lists are the way to go.
chris
Old 03-08-2017, 7:25 AM
Update: (i'm the original poster)
I also have a Uniden 436, that wasn't showing the City of Hartford system in the full database, when set to the Canton zip code and a range of 30 miles. I tried running the Auto Locate function, and now Hartford appears in the full database. The scanner isn't picking up audio on any of the talk groups, but i assume that's a distance/antenna issue.
I've had the 436/536 for 3 years, and never tried Auto Locate before.
Old 03-19-2017, 8:36 AM
I used to live in Farmington on the Bristol line and never was able to pick up the Hartford EDACS. Unless you are in a high elevation I doubt you can pick them up from Canton. I suppose you could try an outdoor antenna.
