I think you have some things confuzzed..with the terms you are using.
PL's are subaudible interference elimation tones...and are specific to the station you are listening to (if they are using one...most do). If the scanner is in a PL search mode, you will still hear every other station with other tones as the scanner stays in CSQ mode. With Uniden scanners, there are typically three modes of PL operation:
ON
OFF
PL Search
FM is a type of modulation and is not a PL tone or anything remotely close to PL tones (same with WFM, NFM etc)
Insert perceived importance here
Insert all the useless scanners you own here
Insert all your unimportant affiliations here
Thanks for playing!
