Question #1 -
Originally Posted by AWH100
How did you know under system type to pick "Type 2, 800 standard", when the info on Radioreference web page say's: "type 2 smart zone" ? Why don't they list it as:"Type 2, 800 standard"? Somehow you are suppose to know that??? Why not "type 2 800 MHZ Splinter" ??
Since I am a donating member to RadioReference and I have ARC396, I had the ability to simply select the CTSP system from the database and download it right into ARC396. I then cleaned it up to only include the Talkgroups that I wanted, how I wanted them in each Group, listed only the Control Channel Freqs and ensured that I selected "Control Channel Only" mode in the Trunk System Parameters tab. I can't recall what a "Splinter" system is but I am almost certain the database would have listed something along those lines to help those programming the system correctly.
Question #2 -
And my second question is, under frequencies you have to list all the 800 frequency of all the groups that you want to listen to correct?? Then go and list the trunk ID that you want to listen to in that group and don't put any in that you are not interested in. This helps alot. Most trunk sytems are set up like this??
See above for how I handled the frequencies and yes, you can create a group that just has the Talkgroups that you want to listen to. An example is my "Select IDs" Group which has the Troops that are in my area and the other IDs that I want to hear if I only want to scan a few Talkgroups. I hope this helps and I am sure you'll be able to swap around the Groups to customize the way you want to listen to the CTSP. Good luck!
-MikeMike
Central CT Shoreline
