MPT system in Mohegan Sun Casino
I'm trying to work out the band plan for this MPT system.
The left column are the frequencies currently listed in the RR DB.
The middle column is the actual MPT channel number from the control channel.
The right column is my best-guess computed frequency using ...
Base=935.0 Step=12.5khz Offset=1
935.1500, ?, ?????????
935.7000, 57, 935.7000
936.2125, ?, ?????????
?????????, 92, 936.1375
936.6625, ?, ?????????
937.1625,174, 937.1625
?????????,237, 937.9500
938.2000,257, 938.2000
?????????,292, 938.6375
?????????,314, 938.9125
939.2125,338, 939.2125
935.15 Mhz is the control channel. I didn't catch the channel number for it so I'm not too worried over that. The other channels seem to line up - except for four. They aren't listed in the RR DB. Either (a) they are missing from the DB or (b) they are input channels.
Can someone confirm either (a) or (b) above - or suggest an option (c) ??
-rick
