Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Connecticut Radio Discussion Forum
Connecticut Radio Discussion Forum Forum for discussing Radio Information in the State of Connecticut.
Old 12-12-2006, 08:27 PM
central190's Avatar
Question Suffield Fireground Chs
hi all maybe someone can help out on this one that know the suffield area i do i am geten confused on the fireground chs now which one to listen to i know they are simplex why do they need three small twn they are
the old FG CH 14 151.xxxx says in the scanner master it is now a the input to 156.xxxx
fireground 1 150.7750 D134
fireground 2 155.36250 D134
fireground 3 159.1275 D134
TACTICAL 153.9500 ever in use
svs 173.2250 unkown what this ch is for would this be for a mobile repeater on the rigs
Old 12-12-2006, 08:31 PM
Send a message via AIM to spatch713
173.2250 is licensed as a MO3 for Suffield EMS so its a vehicular repeater... not sure if its used.
The image is cracked but so is the view...
Old 12-13-2006, 07:42 PM
PJH's Avatar
PJH PJH is offline
The SystemKey Master
Send a message via AIM to PJH
The RR.com listing is correct. Don't know about scannermaster
Insert perceived importance here
Insert all the useless scanners you own here
Insert all your unimportant affiliations here
Thanks for playing!
Old 12-13-2006, 07:45 PM
PJH's Avatar
PJH PJH is offline
Forgot to add..
The old primary channel of 154.13 is still licensed, but not sure how often..if at all.. its used. 99% of all calls are on the repeater 156.07500/158.94000. I believe the old fireground "Fire 2" of 153.95000 is still programmed into the radios.
Thanks for playing!
Old 12-13-2006, 09:22 PM
central190's Avatar
Default suffield fire ch
this summer when they the had the fire in windsorlocks at the mill i was switching to see what was going on and heard units responding to the scene on the 151.4300 i thought to myself that was odd that was the fireground ch 14 then i switched to the main ch i have heard suff on that ch like when they had the fireworks for the july 4 celebration when command has wanted the units to go to simplex so they won't tie up the the rptr ch 156.075 for the detail.The scanner master says that 151.4300 is the input to rptr ch.hmm
Similar Threads
Susquehanna Co Question Abt Fireground brey1234 Pennsylvania Radio Discussion Forum 0 01-04-2006 10:33 AM
Uniden 396T help geod49 Uniden Scanners 33 12-13-2005 05:49 AM
Baltimore City Fireground TGs mlevin Maryland Radio Discussion Forum 0 08-10-2005 09:56 AM
Eastern Slope DTRS Updates jimmnn Colorado Radio Discussion Forum 15 12-20-2004 11:31 PM
Need Douglas County Fireground Channels LFRfreak Colorado Radio Discussion Forum 0 12-05-2004 01:56 AM
