Originally Posted by mdulrich
You might want to rerun the report. I got 24 pages with a frequency on every line.
I ran the report numerous times, each time it omitted the same frequencies. Did you compare the Moleston Fire District entries? I'm not sure you're looking at the same thing I'm talking about.
Results from FCC license detail page:
Code:
1 46.08000000 20K0F3E FB 1 0 150.000 41.12925 -74.04125 SPRING VALLEY ROCKLAND NY
1 46.18000000 20K0F3E FB 1 0 150.000 41.12925 -74.04125 SPRING VALLEY ROCKLAND NY
1 46.48000000 20K0F3E FB 1 0 150.000 41.12925 -74.04125 SPRING VALLEY ROCKLAND NY
2 46.08000000 20K0F3E FB 1 0 150.000 41.19175 -74.01903 POMONA ROCKLAND NY
2 46.18000000 20K0F3E FB 1 0 150.000 41.19175 -74.01903 POMONA ROCKLAND NY
2 46.48000000 20K0F3E FB 1 0 150.000 41.19175 -74.01903 POMONA ROCKLAND NY
3 46.08000000 20K0F3E MO 35 0 6.000
3 46.08000000 20K0F3E MO 20 0 110.000
3 46.18000000 20K0F3E MO 20 0 110.000
3 46.18000000 20K0F3E MO 35 0 6.000
3 46.30000000 20K0F3E MO 15 0 10.000
3 46.32000000 20K0F3E MO 35 0 6.000
3 46.32000000 20K0F3E MO 20 0 100.000
3 46.36000000 20K0F3E MO 20 0 100.000
3 46.36000000 20K0F3E MO 35 0 6.000
3 46.48000000 20K0F3E MO 35 0 6.000
3 46.48000000 20K0F3E MO 20 0 100.000
3 460.51250000 20K0F3E MO 50 0 2.000
3 465.51250000 20K0F3E MO 50 0 2.000
3 465.53750000 20K0F3E MO 50 0 2.000
Results from PDF file:
Code:
MOLESTON FIRE DISTRICT KED435 46.08000000 1 0 FB PW SPRING VALLEY
MOLESTON FIRE DISTRICT KED435 46.08000000 1 0 FB PW POMONA
MOLESTON FIRE DISTRICT KED435 46.18000000 1 0 FB PW SPRING VALLEY
MOLESTON FIRE DISTRICT KED435 46.18000000 1 0 FB PW POMONA
MOLESTON FIRE DISTRICT KED435 46.48000000 1 0 FB PW SPRING VALLEY
MOLESTON FIRE DISTRICT KED435 46.48000000 1 0 FB PW POMONA
See the problem now? It's clear as day to me. The PDF report completely omitted 46.30, 46.32, 46.36, 460.5125, 465.5125 and 465.5375, even though they are all valid frequencies licensed under the same call sign.
I would politely and respectfully ask that unless you are in the position to have the definitive answer to this issue (Lindsay), you refrain from posting and taking the thread off track as happens all too often around here. Thanks.
