Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum Topics regarding the RadioReference Database
Old 11-01-2009, 07:38 PM
Default Type II downloads as Type I
I downloaded Little Rock Public Safety (the one below) which says it a Type II hybrid, but when I looked at it in freescan it says it is a type I, seems to work, should I change it to type II/p25 or type II or just leave it alone
Little Rock Public Safety Trunking System, Little Rock, Arkansas - Scanner Frequencies
Uniden BCD996XT
FreeScan Programming software
Old 11-01-2009, 08:26 PM
Wiki Admin
Clearly this isn't a database issue; a better place to ask this would be in the Arkansas forum. However, just at first blush, you wouldn't want to put it in as a type 2, I'm pretty sure. As long as you've installed the fleetmap, you should be good to go
73 Mike
Old 11-01-2009, 08:27 PM
Chauffeur6's Avatar
The simple answer is: If it ain't broke, don't fix it.
The expanded answer is: A Type IIi Hybrid system is not a pure Type II system, and it's most certainly not a P25 system. It's exactly what it sounds like, a mixture of Type I and Type II, or more specifically, it's a Type I system that uses Type II talkgroups. So for the purposes of interacting with a trunk tracking scanner, it's a Type I system, and will still require a fleet map.
Old 11-01-2009, 08:29 PM
73 Mike
Sorry can you move to where it needs to be, Since I downloaded it from RR database thought it would be a DB issue, as in what RR is saying it is and what it DL's as, is different.
Uniden BCD996XT
Old 11-01-2009, 08:32 PM
OK thank you, that answered my question
Uniden BCD996XT
