Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum - This forum is for questions about the database such as how to use it, layout or usability issues or suggestions for improvement. It is not for pointing out wrong information or getting help with programming.
Old 02-08-2010, 6:07 PM
Arrow What does "FMN' stand for?
Hello gents. Just wanted to know what "FMN" signified in some mode listings in the database. Would
appreciate any info.
Thanks,
RUSHFAN
Old 02-08-2010, 6:10 PM
K8PBX's Avatar
FM Narrowband
See here: http://wiki.radioreference.com/index.php/FM
Steve
mtindor's Avatar
OH/WV DB Admin
Thanks,
RUSHFAN
FM Narrow / narrowband FM. Typically, FM would be 20 khz or thereabout, and NFM would be 11.25 khz or less. If your scanner doesn't do narrowband FM, it's not a big deal. But if your scanner does have an NFM mode, you should use it on those frequencies that are listed as NFM.
That's in a nutshell. Someone with more knowledge of the whole requirements of agencies switching to narrowband will likely chime in with better info.
Mike / AA8IA
PSR500/PRO197/BCD436HP/TRX-1
Email: my username @gmail
Old 02-08-2010, 6:11 PM
mciupa's Avatar
Forums Moderator
FMN=Frequency Modulation- Narrow (FM Narrow)
Read an excerpt from the WIKI: NFM - Narrowband FM (called FM on most scanners) -- is used on most current analog public safety communications and the total deviation is generally limited to 30 KHz down to about 12 KHz
