Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum - This forum is for questions about the database such as how to use it, layout or usability issues or suggestions for improvement. It is not for pointing out wrong information or getting help with programming.
Old 11-10-2010, 10:03 PM
Default Tsa
At this page Transportation Security Administration - The RadioReference Wiki there are listings for TSA nationwide. I've got 4 active frqs for Denver Airport, Colorado but don't know hot to submit info to that page.
On most pages I've visited there is a column with "Submit" at the upper part of the Web page but not at the TSA page. Perhaps someone from RR simply checks the federal section from State pages and inserts new info from time to time?
Any ideas? Thanks in advance.
Old 11-11-2010, 2:21 AM
datainmotion's Avatar
I would suggest going to Federal Government Scanner Frequencies and Radio Frequency Reference where you'll find the existing listings for TSA in Colorado as well as a "Submit" button.
Travelling through Colorado?
wir hören zu
Old 11-11-2010, 5:34 AM
Wiki Admin Emeritus
Or if the information is not validated (in which case it doesn't belong in the db) and you wish to put it into the wiki - you can do that yourself. You can edit the TSA wiki and put in what you find. That's why there's an 'Edit' tab on the left.
Right on the wiki home page at the very bottom you will find a section called 'Editing and Commands'. This section contains links to the various editing commands you can use.
Best Regards...Mike
Old 11-11-2010, 1:26 PM
If you want to look for a model for how it is done in the reference county of Harris County, TX. Take a look at the federal page:
Federal Scanner Frequencies and Radio Frequency Reference
...no TSA section is found.
If you look inside an airport page:
Bush Intercontinental Airport/Houston (IAH) Scanner Frequencies and Radio Frequency Reference
TSA is listed here.
I think a challenge with TSA is that there appear to be common frequencies and site specific frequencies.
Check out the MT Fed Files Blog for more information on TSA and to see how usage can vary from facility:
http://mt-fedfiles.blogspot.com/search?q=TSA
If we're taking a vote, I like the approach taken by Harris County. It allows the most flexibility to address site specific differences...
Old 11-11-2010, 5:18 PM
LAflyer's Avatar
Global DB Admin
Feel free to submit verified frequencies to the DB via the submit link on the Denver airport page.
Denver International Airport (DEN) Scanner Frequencies and Radio Frequency Reference
In my travels I have noted very different frequency and NAC code usage from airport to airport, so any airport specific information can be made to appropriate airports page.
Old 06-17-2012, 1:34 PM
Appears to be encrypted at GPT.
Old 06-18-2012, 6:55 AM
ecps92's Avatar
The Wiki is editable by anyone to add/modify/update.
What you also need to do is find a suitable page in the RRDB and make your local submissions there. Maybe under a state Federal Page or even a page for the Airport itself
PS - post them also here for those who don't browse the Wiki or the RRDB
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 06-18-2012, 10:23 AM
ChrisP's Avatar
El Paso, TX (KELP)
166.2875, N002 - TSA Backscatter X-ray operators
172.1500, N001 - TSA
- Chris
Chris Parris
Federal Wavelengths Columnist, The Spectrum Monitor Magazine, www.thespectrummonitor.com
chrisparris@thefedfilesDOTcom
http://mt-fedfiles.blogspot.com/ @TheFedFiles on Twitter
