Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum This forum is for questions about the database such as how to use it, layout or usability issues or suggestions for improvement. It is not for pointing out wrong information or getting help with programming.
Old 12-09-2012, 4:52 PM
Default Becoming database administrator
I was just curious as how you become a admin for the Massachusetts area?
Old 12-10-2012, 8:37 AM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Send a message via AIM to KE4ZNR Send a message via Skype™ to KE4ZNR
Having a consistently outstanding submission history here at RR with accurate info is one of the big criteria. Also extensive accurate knowledge
of how frequencies are used in MA. Add in that existing MA Database Admins
have some insight into potential candidates.
A lot of consideration goes into the process to make sure the integrity of the database is maintained.
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
http://instagram.com/KE4ZNR
Old 12-10-2012, 12:21 PM
Chauffeur6's Avatar
DB Admin
As Marshall points out, having a solid, consistent history of accurate, relevant and representative submissions is a key criteria for consideration. If you have a history of poor or rejected submissions, which indicates a lack of knowledge or understanding about the area, that's going to kill your chances of even being considered. If you submit data that is inaccurate, counterproductive, misleading or would serve to lower the quality of the database, you certainly would not be entrusted with the ability to directly maintain the database, as you'd wind up doing more harm than good.
Generally speaking, of course.
