Originally Posted by Blackink
Could someone explain to me what I'm looking at after I click on a License#, like WPYP425 in the database?
Here's that link WPYP425 (CAPITAL FIRE MUTUAL AID SYSTEM) FCC Callsign Details
Scroll down the page until you see the list of frequencies and you'll see 155.2650, the one I'm talking about. That frequency is listed twice for Berlin. (That same frequency is listed further down with no location attached to it).
Anything in blue is a link. In order to understand the info for WPYP425, you need to know what most of the other columns are for. In this case, 155.265 is listed twice under the
Station Class Codes, FB, or fixed base. Each one has a different
Emission_Designator One is "Wide band" and the other is the new narrowband (11K2F3E). The wide band is no longer legal, so they had to update the license to show compliance with the new
Narrow band mandate . The 3rd and 4th listings are for MO, or Mobile. This means that the mobiles transmit back to the fixed base on the same frequency(very typical). Mobiles do not show a specific location, because they are are allowed to operate 40.0 km radius around a fixed location.
ULS License WPYP425 - CAPITAL FIRE MUTUAL AID SYSTEM - Location 2 This link is the actual FCC license, which has a bit more info, The link for
WPYP425 is a reformat of the FCC data with some neat location graphics, provided by RR, but the actual FCC link is at the very bottom. Are you sorry you asked
What are the frequencies listed there and why do I see 155.2650 listed for City: Berlin, County: Washington, State: VT, And that frequency isn't listed anywhere in the general database for Washington County (the first link above)
The reason you don't find 155.265 in a search is because it has not be entered into the RR database, which is different from the FCC license database. In this case, no one has confirmed that 155.265 is actually in use. You can also see that it is not listed under Capital Fire Mutual Aid System on the Wash county page. That does not mean it isn't..just that no one has entered it yet. The RR database contains only those frequencies members have confirmed. It is quite common for an agency to license more frequencies than they actually use for future expansion/use.
When I do a frequency search for 155.2650, it comes back listing:Vergennes Area Rescue Squad, EMS (serving Swanton & Highgate), and EMS (for Deerfield Valley Rescue Windham County)?
Frequencies are often used by multiple agencies in the state. As long as they are over 30-50 miles(approx), they won't interfere, so they can be "reused". There are complicated factors that the licensing agency can use to determine if they can be reused without interference.
