Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum - This forum is for questions about the database such as how to use it, layout or usability issues or suggestions for improvement. It is not for pointing out wrong information or getting help with programming.
Old 04-08-2014, 10:12 AM
Eng3ineer's Avatar
Default Help with TX database submission/rejected
Hello,
Not trying to stir the pot. But I can't get a reply back on my submission # 144526 along with that my PM have gone unanswered.
I sent a submission back in January on Texarkana Bi State system Ticket # 144526.
What I found and submitted was that The Texarkana Texas Fire Dept. has change up the departments station alerting system and in doing is now using another ID/ channel 43223 strictly for station alerting & dispatch only.
The former alert ID/channel # 43216 is still used as well, but now for checking en route, and daily operations and such. I submitted this new ID of 43223 and after few days i'm guessing that my submission was rejected as the reply back I received was the following below and the database was never updated for Texarkana, Tx Bi-State.
43223 is the same talkgroup as 43216. 43216 + 7 status bit = 43223 indicates a dispatcher initiated multi-select.
I'll be the first to tell you that don't understand all the in and out and the hows of a trucking system. After that reply i've have sent/ reply back with notes and a PM all which have gone unanswered.
Thanks for any help.
Jason
Old 04-08-2014, 10:33 AM
Jay911's Avatar
Whatever scanner you're using, you need to turn the "ignore Motorola status bit" function to "ignore" rather than "allow". These talkgroups are indeed the same channel.
By the way, it's a "trunking" system, not a "trucking" system, and more details on status bits can be found here: Motorola Type II Smartnet - The RadioReference Wiki
Old 04-08-2014, 7:17 PM
Eng3ineer's Avatar
Thanks for the link it makes a lot more since now.
I'm using the older Radio Shack Pro 90 for my two fire feeds so, I have no way top turn on or off the Motorola status bit. I have a spare Pro 90 and tried to reprogram the fleet map and so far no luck with it. I still get the 43223 for the station alert and 43216 for en route and such.
I have BCT8 that's used for my PD feed gonna give it try when get a chance and see what happens.
On another note wouldn't still be helpfully if the other Talkgroup ID's were added to database list?
Thanks,
Jason
Old 04-08-2014, 7:27 PM
ecps92's Avatar
Only the older Scanners don't handle the Status Bit.
All the newer scanners understand the info and display the correct info.
If you listed each varience of the Status bit, that would be 16 listings per Talk-Group. Way too many to be listing.
Thanks,
Jason
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 04-08-2014, 7:53 PM
Eng3ineer's Avatar
Thanks,
I didn't figure the older scanners would work after trying to reprogram the fleet map with no luck... Guess I need to look into updating. $$$$
Yeah that would be a lot info for each talkgroup, but could be very helpful for those with older scanners. :- )
Old 04-09-2014, 6:39 AM
ecps92's Avatar
That is where reading the manual, and having the wiki (see prev link) come in handy.
No need to add extra TG's that May or May-Not get used
Thanks,
Bill N1KUG
Old 04-09-2014, 9:59 AM
Eng3ineer's Avatar
Good news set up the BCT8 and it's working great. No longer having the 43223 ID show up it all working under ID 43216.
Yeah, It was a big help. Out of all the searches that i've done some how I missed that wiki on status bits.
But it sure didn't help by not getting a reply back to my PM or my notes. That's why came here to ask and was helped out right away and my question answered.
Thanks again to those that helped and replied back.
Jason
