Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum This forum is for questions about the database such as how to use it, layout or usability issues or suggestions for improvement. It is not for pointing out wrong information or getting help with programming.
Old 05-23-2014, 4:07 PM
TedRHayes's Avatar
Default Changed Site field in Change History Record
I find the info provided in the Change History Records for Site changes to be of limited value. For example, here's the value for a recent change on the Ohio MARCS-IP system:
"Changed Site # 027 (Grafton CI) to 027 (Grafton C.I.)"
Even if you dig down into the associated pages it is often not clear what if anything has been changed for the given site.
Would it be possible to add more info, e.g., Changed/Added CC, Updated GeoLocation, added sister sites, etc., to the changes records. When I discussed this with one of the DB Admins, he indicated that the include info is controlled by the backend of the RR system.
Thanks,
Ted
Old 05-23-2014, 4:37 PM
hfxChris's Avatar
He's correct, the updates are automagically generated by the database, and we have no direct control over the information given in the updates when we make changes.
This would need to be a modification made to the database software...
Pro-66 | Pro-96 | Pro-97 | Pro-2055 | Pro-137 | PSR-400 | BCD396XT | BCD996XT | HP-1 | Kenwood R1000
Nova Scotia, Prince Edward Island and Newfoundland & Labrador database administrator
