R
retiredmich
Guest
When going to any State on the Database (US) & i click on a county & high light that CO it will show a RED circle & the mileage it covers. That mileage it show's is that from the middle of the circle ?
Are you on the RR database or the ULS. I cannot get a red circle on the RR database.
Never knew that feature existed .. Thanks for the tip !!!
I wouldn't use the RadioReference Database distance to tell you what you should and should not program into your scanner. They are generally a random number entered by a database admin for units that support GPS and rarely reflects the true coverage distance. Real radio propagation depends on things like terrain, height, and numerous other things that is not reflected by the database.
If you submit location corrections to the db it will be updated
What exactly is the policy involving the range of a system? Should the radius be covering the agency like Paul mentioned above? I also get a good amount of stuff fro Connecticut as well.
