BM82557
The site has some kind of database issue at the present time. This is what I receive when I click on the Reference Database area on the RR home page - Invalid Country ID:
The problem seems to be with a redirect on the homepage.
You can still get to the DB directly using this link, and then navigate around from there.
RRDB: US Homepage
Hope this helps,
Is this related to the import of data? I'm using PSRedit, and when I try to download data, after I specify United States, the State Dropdown list is blank
Having the same problem Invalid County ID...
I am definitely not knowledgeable enough to make a positive connection,,, but the FCC Universal Search system is also down for a rebuild until the 8th. Maybe there's a connection with the license access portion, I don't know.
Ronaldski, Thanks for reporting the problem upline.I submitted a mantis ticket for this issue - its used as the 'work request' system here.
johnls7424, If Ronaldski was the first RR-staff-member to notice the thread, then they've only known about it for approximately one hour. It might be a while before it is resolved.Having the same issue still. It's 4:00PM on the east coast. Still have " invalid country ID"
