I just had a thought for larger trunk systems such as Alberta First Responders' Radio Communication System (AFRRCS) Trunking System, Multiple Locations, Alberta - Scanner Frequencies or Michigan's Public Safety Communications System (MPSCS) Trunking System, Statewide, Multi-State - Scanner Frequencies, which have gigantic lists of tower sites. I'm suggesting that the header "System Frequencies" (and possibly also "System Talkgroups", and/or subcat titles as well) should have a widget on them that make it possible to collapse the entire section, so you don't have to scroll through hundreds of sites if your end goal is to get to talkgroups, for example.
Alternatively, a simpler solution would be to have bookmark links near the top of the DB entry (underneath the title and "Discuss/Wiki/Watch/Download" buttons) that let you jump to sections with a click.
