St. Clair Cencom issues
RyanVogt
I have used FreeScan and the import from RR trunked system to import and upload the Frequencies for the Starcom21 P25 system used by Cencom in St. Clair illinois. However it says i am missing APCO Band Plan? is this something i need? i havent heard anything in a couple hours since i uploaded it.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Your scanner should load the Band Plan from the control channel when it first receives it.
That's not guaranteed; some systems are implicit, others explicit.
Implicit - Radio firmware plus CC messages determines channel/frequency pair
Explicit - System assigns the actual TX and RX frequencies over the CC
While explicit is typically used for VHF/UHF systems, I've heard of it popping up on 700/800 systems as well.
In this case, best bet is to select P25 Auto or whatever the appropriate selection for the scanner model is.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
We had a UHF system suddenly stop broadcasting the bandplans over the control channel. Until they were input manually, nothing was heard.
trido
Southern In
when i import Starcom atleast for me Freescan sets it as Mot Type II
I change the type setting to P25 Standard[
QUOTE=RyanVogt;2843429]I have used FreeScan and the import from RR trunked system to import and upload the Frequencies for the Starcom21 P25 system used by Cencom in St. Clair illinois. However it says i am missing APCO Band Plan? is this something i need? i havent heard anything in a couple hours since i uploaded it.[/QUOTE]
