Go Back   The RadioReference.com Forums > Site Administration Forums > Database Discussion Forum
Database Discussion Forum - This forum is for questions about the database such as how to use it, layout or usability issues or suggestions for improvement. It is not for pointing out wrong information or getting help with programming.
Old 06-09-2018, 1:41 PM
VA3DBJ's Avatar
Ontario Database Admin
Default Radio Reference API
Not sure if this is possible, but I have noticed that my API script, being registered using http://www.va3dbj.ca, does not work now, since I have started using the https://www.va3dbj.ca since enabling the SSL. SSL/https seems the preferred method now, since all the browsers are now forcing secured connections.
It does still work when someone connects to http.
Do I have to re-register for another code for https and code my sites using both? or can it be changed to work for both http and https, or just operate using just the domain itself?
Uniden BCD536HP+DMR+PV/BCD996XT/BCD896T/RS Pro-2004/2021
Kenwood TM-D710/Kenwood TM-V71A/Yaesu VX-7R/Baofeng UV-5RE
Database Administrator for NL,NWT,YK,NT,ON
Old 06-10-2018, 8:51 AM
blantonl's Avatar
Founder and CEO
What API methods are you using? Remote display of database content? Example page?
Lindsay C. Blanton III
CEO - RadioReference.com / Broadcastify
Facebook: RadioReference | Broadcastify | Twitter: @RadioReference
Old 06-10-2018, 10:22 AM
VA3DBJ's Avatar
Yes, I am trying to show content for CP Rail.
http://www.va3dbj.ca/scanner-radio/railway/
https://www.va3dbj.ca/scanner-radio/railway/
I have included the code at the bottom of the page as an example. You can see the info via the http, but not the secured https.
<script language="JavaScript"
src="http://api.radioreference.com/js/?key=########&scid=49884">
</script>
It think when I registered the domain, way back in the day, it was registered as http://, as that was pretty much the norm at the time. Not sure if I should have registered just with www.va3dbj.ca, or even if the registration page would have even taken it.
Old 06-11-2018, 7:26 AM
blantonl's Avatar
Founder and CEO
Try changing the code to
Code:
src="https://api.radioreference.com/js/?key=########&scid=49884">
</script>
If you are serving https from your site, call the API via https from RadioReference
Old 06-11-2018, 2:47 PM
VA3DBJ's Avatar
D'oh. Why didn't I think of that. I had though the script was specific in nature. That fixed it.
Thanks Lindsay.
Old 06-11-2018, 5:26 PM
ChrisABQ's Avatar
I added the live scanner to my site abqscanner.com, I first had requested it as http and it worked. I then moved the site to https and it stopped. I requested another code for https and it still does not function with SSL. It's the only page on the site that is not secure.
BCD436HP w/ProVoice & DMR - BCD996P2 w/ProVoice - BCT15X (2) - UniTrunker DSD+ - Pro-2011(my very first radio) - Baofeng UV-5R/UV-82
http://abqscanner.com - https://dynodan.com
Old 06-12-2018, 6:53 AM
blantonl's Avatar
Founder and CEO
You aren't calling the embed API code with https, you are calling it with http
I updated the code on the feed management page to default to https now.
You need to call https://api.broadcastify.com
Check your feed management page technical tab for the correct code.
Old 06-12-2018, 10:10 AM
ChrisABQ's Avatar
Thanks Lindsay. I had previously seen a blank box in that area rather than the player. I updated it but the SSL notification on the page is still a yellow triangle (on Chrome), but it is functional.
