Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Delaware Radio Discussion Forum
Delaware Radio Discussion Forum Forum for discussing Radio Information in the State of Delaware.
Old 08-18-2008, 01:13 PM
Roach112683's Avatar
Default Programming ITAC and TALK Channels
I was wondering how to program the ITAC channels. The site lists them as conventional channels but the talk channels as project 25. How do I program these into my Pro-96? I tried setting the bak as conventional and the channels as FM but it doesn't work. What do I need to do?
Old 08-18-2008, 01:26 PM
ecps92's Avatar
Send a message via AIM to ecps92 Send a message via Yahoo to ecps92
ITAC Channels are Conventional and 156.7 Hz for the CTCSS, these are Nationwide Channels.
Bill Dunn N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Feeding USCG Sector Boston at
http://www.scannewengland.net/index....geid=nesflogon
Old 08-18-2008, 01:45 PM
well when I set it for conventional it hangs on one channel and doesn't scan them. What do I need to set the bank to conv or mot?
Old 08-18-2008, 03:42 PM
ecps92's Avatar
Maybe there is an open carrier ?? Is it hanging on the CTCSS of 156.7 Hz ? Which one channel does it hang on ?
Bill Dunn N1KUG
Old 08-18-2008, 03:52 PM
It hangs just on the ITAC 1
I have them all set for FM and Conv in the scanner so I don't know why it should not be scanning the bank.
Old 08-18-2008, 04:40 PM
ecps92's Avatar
Sounds like someone has an open microphone or you just suffer from a birdie on the channel.
a.) Take the antenna off the radio, does it still suffer the problem ? No? then Open Mic, lock it out for now
b.) Still have the open Mic? Birdie. Lock it out.
Bill Dunn N1KUG
Old 08-18-2008, 06:09 PM
I also have the bank listed as open should I list it as closed?
I always thought if it was "closed" that it would only search for talk group IDs and not conventional channels. All the channels when I tried what you said I had to end up locking out all the channels.
There must be something I am missing here
Old 08-18-2008, 06:31 PM
OK I'm going to see if this works. I programmed the ITAC and TalK Channels the same way as Ocean City is in my scanner because they also use conventional channels. Their system is set on EDACS so I set the ITCA and TALK channels to those to see what would work. It scans but there is no activity on them so I cannot know for sure if they work or not. Won't know till the weekly test of ITAC on sunday.
Old 08-19-2008, 03:37 AM
KB3JUV's Avatar
Send a message via AIM to KB3JUV Send a message via MSN to KB3JUV Send a message via Yahoo to KB3JUV Send a message via Skype™ to KB3JUV
You won't hear much activity on the ITAC's anyway. DSP does a weekly test on their assigned ITAC channel but other than that, thats all I know that is actually used on a weekly basis.
KB3JUV/AAT3OT
Delaware Emergency Management Agency
Lewes Fire Department Station 82
Christiana Fire Company Station 3
www.kb3juv.com
Old 08-19-2008, 06:21 PM
Yeah I know. The only reason I put it on was because we have had a series of thunderstorms in the area which have taken down the trunked system so I want to be prepared for the next one.
Old 08-21-2008, 11:34 PM
Audiodave1's Avatar
Hello,
Do not set them to trunked. They are standard conventional channels.
Dave
If bad sound were fatal Audio would be the leading cause of death!
Old 08-22-2008, 06:13 PM
They ar enot set to trunked. They are conventional but if I keep them set to Conv and FM I get the hold on all the channels and it does not scan. I believe Ocen City's channels are the same way which are non-trunked conventional channels and they are set for EDACS on my scanner so that is what I set my ITAC and TALK for.
