Originally Posted by Dave520
You can buy an updated list at the track for $5 that has all the current frequencies being used. Let us know what type of scanner you have and maybe someone will have a file for you to upload directly into your scanner.
i have the gre-500 i have a list that i got from int its just that two of the drivers have the same secondary frequencies, just wanted to know if anyone had the secondary for these two drivers so i know which is which the drivers are kevin harvick and greg bifle the list shows that both drivers are using 462.0250, just looking to see if someone knows which frequencie to use for which driver for the secondary. yes i did check the wiki thet only show primary frequencies, thanks in advance for youre help.
