Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Delaware Radio Discussion Forum
Delaware Radio Discussion Forum Forum for discussing Radio Information in the State of Delaware.
Old 09-30-2008, 06:43 AM
Default Clayton - Smyrna PD & other local
I'm not hearing Clayton, Smyrna, or any local municipal PD's from my home, which is in Clayton. I also have an external antenna installed. I have NCC programmed....I hear a lot up north, but nothing local or south.
Is anyone able to hear any municipal PD from Middletown south? I have the BC 996 and the systems and freqs have been imported from RR.
Anyone who has any tips is appreciated.
'73,
Jim
wb3j
Old 09-30-2008, 06:10 PM
de784's Avatar
Default Muncipal pd
Like Sussex county most of you local pds are dispatched through suscom or kent com,Local pd talk groups are mostly chit chat between cars
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
Old 09-30-2008, 06:36 PM
h8tdigitalradio's Avatar
Hello,
SPD does its own dispatching. As previously mentioned, most Municipal PDs are dispatched by ReComm, KentComm, or SusComm. I just monitored Clayton PD chit-chatting. Make sure you have the TGs programmed:
TG 19408: SPD1 (Smyrna PD Dispatch 1)
TG 19600: CPD (Clayton PD)
Clayton and Smyrna affiliate to the NCCo and Kent Co Zones. If you use Multi-Site Trunking, and program both Sites, you should have more chances of hearing SPD and CPD from the NCCo or Kent Co Site.
HTHs
73
Dave AKA The Tripzter
©MMIV-MMIX by "The Worst of Tripzter®" All rights reserved.
Old 09-30-2008, 08:33 PM
Thanks for the reply.....I do have those Tg's programmed, but aren't hearing them
73,
Jim
wb3j
Old 09-30-2008, 08:49 PM
Hello,
The Group you have the TGs programmed in, is it enabled? Not L/O? ID Scan or ID Search? Try pressing HOLD, then use the Scroll Knob to scroll through the Scan List to SPD and see if you get any comms.
73
Old 10-01-2008, 06:44 AM
Hi Dave...
Yup..enabled, no lockouts. I toggle between ID scan & ID search from time to time. I checked my scanner & see Smyrna in a comments field. When holding on the Id, I hear nothing...still.
Jim
Old 10-01-2008, 08:50 AM
mandlair's Avatar
Send a message via Yahoo to mandlair
sometimes they are not that busy,most times during they day they are though.Mike
RADIO SHACK PRO-96/RADIO SHACK PRO-2036/RADIO SHACK PRO-197/GRE PSR500/UNIDEN 200XLT/YAESU VX-7R/KENWOOD TM-V7. callsign KB3LZZ
Old 10-13-2008, 07:43 PM
Audiodave1's Avatar
You will only hear SSX DSP Command if you are scanning the Kent system. The NCC system does not carry it.
Just a note...
Dave
If bad sound were fatal Audio would be the leading cause of death!
Old 10-14-2008, 12:51 PM
hai_akeeba's Avatar
try changing your audio setting to digital instead of all
hai_akeeba
Similar Threads
Programming Scanner Cable Git-R-Done General Scanning Forum 21 10-03-2008 02:26 AM
Local PD channels Q-ball Pennsylvania Radio Discussion Forum 4 10-01-2008 04:51 PM
2007/07/08 VHF Low kkn50 Skip / Tropospheric Ducting Forum 1 07-09-2007 11:14 PM
Vacationing in Uncasville, what to listen to? UFEMTFF Connecticut Radio Discussion Forum 10 07-03-2007 03:32 PM
Galveston talkgroups leawoodcops Texas Radio Discussion Forum 5 06-25-2007 05:39 PM
