Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Delaware Radio Discussion Forum
Delaware Radio Discussion Forum Forum for discussing Radio Information in the State of Delaware.
Old 11-15-2008, 02:38 PM
Question DE TRS System
Okay I have a few questions about talkgroups and frequencies and trunking sites.
1. One my PSR-500, I have KN-CMD (2320) programmed under only the Kent County site. Is KN-CMD (2320) repeated on the NCC Site?
2. I usually hear WPD units on WILCOM ask eachother to go to TAC-C. Whenever I switch over to TAC-C on my scanner, I don't hear anything. Is it some sort of simplex channel or what? I have the TG ID# as 27856. Is that the correct TG ID#?
3. I see that there are 2 other IR sites in NCC, in addition to the main NCC site, Winterthur and Hockessin. I know where Hockessin is but where is the Winterthur IR site located? What units have been heard using the Winterthur and Hockessin sites?
4. Are TALK 1 and TALK 2 used much? Are they simplex channels or repeated channels?
That's All
Thanks.
Monitoring the First State with a PSR-500.
K3QVC Technician
“The future doesn't belong to the fainthearted, it belongs to the brave.”- Ronald Reagan
Old 11-15-2008, 03:30 PM
de784's Avatar
Default Ncc
Negative
It's full time encrypted
This is where Winterthur is Located http://www.radioreference.com/apps/db/?cs=WPWM309
Looks like they use another cc for NCC
For Sussex and Kent used for Fire Ground Operations can't speak for NCC also used when trs goes down
That's All
Thanks.
Hope this helps
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
Old 11-15-2008, 11:04 PM
Audiodave1's Avatar
Actually, Kent Command is repeated on the NCC system full time.
Regarding Talk, They are simplex only.
Seldom used but have been heard up here with non business talk.
Dave
If bad sound were fatal Audio would be the leading cause of death!
Old 11-16-2008, 09:19 AM
de784's Avatar
Default Ncc
Thanks Dave for clearing that up I checked my scanner last night and I don't have the tg in for NCC so when I am up that way that's why I never hear it.
again
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
Old 11-16-2008, 05:27 PM
Audiodave1's Avatar
I find it interesting that NCC patches Kent F/T but Kent does not patch NCC.
Dave
Old 11-17-2008, 08:45 AM
mandlair's Avatar
Send a message via Yahoo to mandlair
Dave
Always wondered that myself,good point Dave.
RADIO SHACK PRO-96/RADIO SHACK PRO-2036/RADIO SHACK PRO-197/GRE PSR500/UNIDEN 200XLT/YAESU VX-7R/KENWOOD TM-V7. callsign KB3LZZ
Old 11-17-2008, 09:46 AM
fmon's Avatar
Hey DE folks, thanks for this thread.
How about this scenario?
Gonna pass through (I-95) on the 26th and return on the 29th to/from Philly. For the 20 miles of travel, it appears the Winterthur site is all I need with a Wildcard in a PSR-500 and 600.
Also, the Wilmington system controls and a Wildcard since it too will be for near the same distance.
Or should I use select TG's for both systems?
Thanks,
Frank
RR Wiki Programming Shortcuts
Old 11-17-2008, 09:55 AM
mandlair's Avatar
Proably I would use the talkgroups,due to the fact of to much radio traffic w/the wildcard.Mike
Old 11-17-2008, 10:01 AM
Audiodave1's Avatar
Hello,
Just use the main system. It covers I95. The Wthr site is a really focused system for that general recreation area.
You should only need the DSP command, data and TAC groups. The TMC group(s) can be a great help as to traffic conditions. Pick the FD groups at your leisure.
If you will be taking I495 around Wilmington I would not worry about that system as they do not patrol the interstate to my knowledge. This system has a very small RX footprint.
Once you get to PA PSP VHF system, 155.505 / .850 to the airport then 155.670 / .910 (Base/Mobile) + 155.460 car-car.
Dave
Old 11-17-2008, 12:28 PM
fmon's Avatar
Thanks guys.
Dave, those PA freqs will be very useful.
Is 495 best route to I-95 exit 8 in Philly? Streets & Maps and Garmin both route me that direction.
Frank
Old 11-17-2008, 01:16 PM
N_Jay's Avatar
Originally Posted by fmon View Post
Thanks guys.
Either 95 or 495 will work.
Don't forget to use 896 and Elkton Rd. to go around the DE/MD line toll.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 11-17-2008, 05:09 PM
hai_akeeba's Avatar
Just an FYI:
Hockessin site is now a full fledged site: WQDN950
hai_akeeba
Old 11-17-2008, 06:04 PM
Default Tac C
What about WPD TAC C? I always hear cops say "go to tac c" or "c". When i go to TAC C, I don't hear anything. I have the ID as 27856. whats wrong?
K3QVC Technician
Old 11-17-2008, 06:22 PM
h8tdigitalradio's Avatar
As previously mentioned, WPD Channel/TAC C is Full Time Encrypted. Thats whats wrong with you scanner. It doesn't or can't monitor encrypted communications. If you want to monitor Channel/TAC C, you will need the real /\/\otorola radio.
73
Dave AKA The Tripzter
©MMIV-MMIX by "The Worst of Tripzter®" All rights reserved.
Old 11-18-2008, 10:59 AM
KB3JUV's Avatar
Send a message via AIM to KB3JUV Send a message via MSN to KB3JUV Send a message via Yahoo to KB3JUV Send a message via Skype™ to KB3JUV
73
And the encryption key!
KB3JUV/AAT3OT
Delaware Emergency Management Agency
Lewes Fire Department Station 82
Christiana Fire Company Station 3
www.kb3juv.com
Similar Threads
Police radio system fails jonescommon Community Announcements and News 28 11-19-2008 03:39 AM
Help with the DE system... Detjohnc Delaware Radio Discussion Forum 4 07-25-2008 09:36 AM
Last call for Pomona PD... iepoker Greater Los Angeles & Inland Areas Discussion 103 02-20-2008 03:40 PM
Tipton eyes switch to new radio system jwheatley Indiana Radio Discussion Forum 0 03-20-2006 07:19 AM
